Price: $119.99 - $199.98
(as of Aug 31, 2024 12:00:18 UTC – Details)
AMTIFO wireless backup camera system is a better choice for RV travel lover. It can be used for safe reverse or driving monitoring.
AMTIFO A9 RV Backup Camera Easy to Install How to install the 7 Inch monitor ?
We provide U-shaped brackets for the 7 Inch monitor. You can fix the display on the dashboard.
How to install the rv camera ?
RV backup camera is an universal camera, which can be used for general installation and also for prewired of Furrion installation, which takes about 30 minutes.
1 4 Channel 2 Recording Function 3 Strong Signal 4 No Delay 5 Touch Button
1 Adjustable Gird Lines 2 Images can be flipped 3 Wide View Angle 4 Durable Metal Camera 5 HD 1080P Image
Perfect for wide variety of large vehicle
REPLACE EXPENSIVE FUIION SYSTEMS:The rv backup camera comes with everything you need to mount to the furrion pre-wired RV, greatly simplifying the installation process. Super easy to install on a Furrion pre-wired RV using the provided Furrion bracket adapter plate and pigtail wires, great for helping reversing and driving.
NO DELAY NO LAG:The wireless backup camera references frequency hopping technology with 2.4GHz WiFi transmission speed and strong anti-interference ability. Also the rv backup camera wireless with monitor are upgraded with dual antennas and unique digital stabilized signal, which increases power, transmission distance, stability, and durability by at least 50%.The signal can reach up to 984 feet in an open area and works in a vehicle range of up to 320 feet.
VIDEO RECORDING FUNCTION:The wireless rear view camera has an SD card video recording and loop recording option, which works just like a car recorder to record what happens around the RV. In case of an accident or collision, the back up camera for truck rv will save the video clips separately to keep the most valuable evidence. The rv camera system supports up to 128G SD card, when the storage card is full, it will automatically overwrite the old video and keep the latest recorded video.
SUPER NIGHT VISION & HD 1080P IMAGES:The wireless backup camera for trucks is also equipped with the most unique CMOS image sensor and 1080P color chip, which can quickly analyze the images and restore the truest colors. The wireless back up camera is equipped with 9 infrared lights for excellent night vision, providing clear images at night or in low light conditions, reducing safety hazards and ensuring safer driving.
150 DEGREE WIDE ANGLE: The trailer backup camera’s wide field of view is perfect for seeing our trailer and multi-lane traffic, providing a more comprehensive view that effectively covers visual blind spots, yet is balanced to avoid fisheye distortion as much as possible.
STURDY AND DURABLE:Backup camera rv for Furrion system featuring a resilient all-metal construction and ip69 waterproof rating, unlike some other cheap plastics, it is more heat resistant and less likely to bend or break.Even if it is exposed extreme weather, it will continue to send images to the driver.Also trailer camera’s power IC on the motherboard has been upgraded from 35V to 60V, so you don’t worry about it stopping working like others.
OTHER MORE FUNCTIONALITIES:Combines the rv wireless backup camera with a large 7-inch screen that allows you to see behind you while driving and assists in backing up, and the display incorporates a sunshade cover that effectively prevents glare from interfering. In the menu, you can switch between front and rear view, and turn on or off the guide line, which is very convenient. The picture is clear and adjustable brightness, contrast, color and so on.
