Price: $85.98 - $79.99
(as of Aug 26, 2024 16:30:22 UTC – Details)
7 Inch HD 1080P Wired Backup Camera Kit
This back up camera for truck. rv has super stable signal transmission, the signal delay and stability that you worry about will not happen with this camera, letting you drive happily and safely.
1 Night Vision 2 High Resolution 3 IP69 Waterproof 4 Image Flip 5 Guide Lines
Packaging List of Back up Camera Systems for truck How to install?
Easy to install: Powered by 1 power supply, just connect the monitor to the Cigarette Lighter(Plug and Play) or hardwired (ACC/Positive Power/Back up Light Fuse) then connect the camera to the monitor with the included video cable.
What’s included?
Sunshade Frame*1 Camera*2 50ft Cable*1 33ft Cable*1 Bracket*1 Double-sidede adhesive*1 Screws*1 Remote Control*1 Car Charger*1 Power Cable*1 User Manual*1
This Backup Camera for RV is Compatible for Vehicles
【Plug and Play】This backup camera for truck trailer is powered using a car charger or 9-36 volt hardwire. This wired reversing camera kit is simple plug and play and requires no prior experience. It allows you to complete the installation quickly.
【Stable Signal Transmission】Do you think the delay of wireless backup camera bothers you? Compared with wireless backup camera, this wired backup camera uses a wired cable to transmit the signal, giving you a more stable signal with absolutely no delay
【Dual-Channel Backup Camera System】This rear view camera is equipped with two cameras, which can provide you with more visibility and make you drive safer. Equipped with an infrared remote control, you can control the monitor remotely. Make your use more convenient and fast.
【Guide Lines and Image Flip】The guide lines of this wired reversing camera kit can be turned on/off, moved up/down, widened and narrowed. You can also adjust the brightness, contrast and color. This vehicle backup camera can meet your multifunctional needs.
【IP69 Waterproof and Night Vision】Backup Camera with Monitor has a 7-inch AHD 1080P display, IP69 waterproof, and 18 LED infrared night vision lights, this back up camera systems for truck allows you to have excellent images in harsh weather conditions and dark nights.
