RV Backup Camera Wireless Recording 2 Cameras – Plug and Play Pre-Wired for Furrion System Night Vision 4 Channels HD 1080P 7” Touch Key Monitor Rear View Camera for Trailer/Trucks/Camper Yakry Y28
Price: $179.99 - $149.99
(as of Sep 07, 2024 16:45:31 UTC – Details)
0
0
1
1
This Trailer backup camera system allows you to connect up to 4 camera so you can see all around you on the same screen. Or you can view just 2 cameras or use the screen for just one view.
9
9
3
3
4
4
5
5
HD 1080P Touch Button Monitor
►Digital High Definition Image Processor HD Image will make you more confident and safer when reversing.
Recording Function
► Works like “dash cam” for your rear,a travel trailer rear view camera to record your surroundings at all times as preventive measures
Suitable for the vehicle pre-Wired for Furrion
►Wireless camper backup camera comes with a Bracket Adapter and Pig Tail Wire Plug Compatible with Furrion Pre-Wired RVs, Installation can be done in 15- minutes or less if your rig has been pre-wired for the fusion camera.
6
6
7
7
8
8
HD 1080P Image
►The large 7 inch screen makes it easy to see what’s behind you, even in the light rain, with vivid and colorful images.
Guide lines ON/OFF
► “Makes backing into a driveway a piece of cake”
You can judge the distance to the backup turn by the on-screen guide grid markers
IP69K Waterproof
► The rv reverse camera supports IP69K waterproof, works well even in rainy days
9
9
Newly Upgraded Dual-antenna Signal for 2024: The rv backup camera adopts advanced chips, digital signals, and dual antennas, improving signal stability and durability by 50%. The signal of rv wireless backup camera can reach up to 830 feet in open areas and work within the range of vehicles within 320 feet.
Recording Function: The wireless trailer camera system has a recording function, like a ”DVR dash cam” that not only connects for reverse/driving use but also continuously monitors and records everything that happens, providing safety measures for you.
Compatible with Furrion Pre-wired RVs: With a bracket adapter and tail wire plug, the rv wireless backup camera for travel trailer can be installed easily in 10 minutes or less, designed to be compatible with Furrion pre-wired RVs.
HD 1080P Monitor with 4-channel and Split Screen Function: The monitor of rv camera system wireless has 4 channels, and you can add 4 cameras to the front, rear, and sides simultaneously to eliminate blind spots. At the same time, the monitor of back up camera for truck rv system supports full-screen/split-screen/quad screen.
Super Night Vision and High-definition 1080P Image: The bluetooth trailer backup camera is equipped with 9 infrared lights and IP69 waterproof, providing clear images and vivid pictures for your safe driving both day and night.
Guideline on/off DIY and 170° Wide View Camera: The horse trailer backup camera wireless system allows you to turn on/off the guide line and adjust the width and height according to your needs. Y28 rv camera is equipped with a powerful sensor and 170-degree wide angle lens, give you a wide field of vision.
Widely Used: Y28 rv back up camera for travel trailers system suitable for RVs, 5th wheels, trucks, trailers, campers, boats, motorhome, trucks, tractors, buses, and other vehicles.
