RV Backup Camera Wireless HD 1080P 2 Infrared Night Vision Bluetooth Rear View Cam 7‘’DVR Touch Key Monitor Kit Adapter for Furrion Pre-Wired RV Trailer Truck Camper Van Crane 4 Channels SINUOER Y87
Price: $119.99
(as of Aug 30, 2024 18:45:20 UTC – Details)
56423542345642354234
7 -inch HD 1080P digital wireless spare camera system, dual -camera and stronger signal double antennas,
Why is SINUOER Y87 wireless spare camera worth choosing?
►Touch button
► 1080P high-definition image monitor provides better viewing presentation
► Super night vision, provide clear images day and night
► IP69K super waterproof wireless camera
► Stronger wireless digital signal
► Guide line on/off
►Support loop recording
► Support up to 4 RV cameras (Rear View/Front View/Side View/Hitch View)
► Compatible with Furrion pre-wired
► Record distance when you are driving or reversing
► Parking aid lines
27542422754242
54451223105445122310
451520451520
.53.5.53.53.5.53
7 -inch HD 1080P touch screen
With HD 1080P resolution system, the digital high -definition image processor HD image will make you more confident and safer when reversing
Recording and Playback
►FHD DVR system, you can loop video, capture along the way,
► Loop recording and local playback make it a dashboard camera.
►SD card saves evidence to protect your rights. (Note: SD card not included)
Guide Lines ON/OFF
► Parking assist Guide Lines On/Off
► Cover the most of dead spots
► The guide wire can quickly turn it on and off according to your needs
23752382375238
23453543452345354345
24523422452342
Night Vision
The RV spare camera system makes your driving safe. The camera allows you to see around your RV to reduce the blind spot and make the reverse easier and safer.
Super Waterproof
►Durable, waterproof camera that works in any weather. Great for everyday use
Backup Camera Bracket Adapter
► Suitable for the vehicle pre-Wired for Furrion
24532322453232
★【Super Dual Antenna Stable Signal】-Dual antenna display enhances the original transmission signal, even installed on a 60ft travel trailer, there is no signal interruption at all, upgrade power, gearbox distance, stability, durability Wireless bluetooth backup camera The system has improved by at least 80%. It can send 1080p video to a display with a stronger signal. The signal can reach up to 984 feet in open areas and works at vehicle ranges of up to 320 feet.
★【IP69 waterproof level】Bluetooth reversing camera with the latest sealing technology, 150-degree viewing angle, good peripheral vision, so that everything you see when reversing the car can be clearly covered, providing comprehensive field of view coverage, wireless backup camera with IP69 waterproof level , and can also withstand extreme temperatures from 4°F ~ 149°F. It also has anti-fog function.
★【Full HD 1080P Image】- This truck wireless reversing camera is designed with 8 infrared and CCD sensors, supports adding 1-4 cameras, can display up to 1080P high-definition images, even in dark environments, you can still View with a 56-foot field of view. But also built-in recording function and loop recording function. After finishing, automatically delete old files, which is very convenient. You will enjoy perfect parking and driving experience.
★【Easy to Install】: Bluetooth wireless digital backup camera and monitor. The backup camera and the camera work together through the wireless bluetooth digital signal, which is very convenient to install and use. You don’t need to worry about the wiring and installation between the trailer and truck no longer affecting your trailer
★【Quad Video Inputs 】– The monitor can watch 4 channels simultaneously, and you can add an additional 3 cameras to avoid all visual blind spots. Input CH1/CH2/CH3/CH4–, you can watch single image or split screen dual view or quad view.
★【Quality Service and Warranty Service】 – 24 hours online customer service, 2-year replacement warranty and lifetime support. 30 days free return service, if you have any questions or need any help, you can contact our background, our professional customer service will answer you in detail
