Price: $129.99 - $119.99
(as of Aug 28, 2024 08:45:25 UTC – Details)
7 -inch HD 1080P digital wireless spare camera system, dual -camera and stronger signal double antennas,
Why is DAJKRTIA D905 wireless spare camera worth choosing?
►Touch button
►HD 1080P HD image and stronger wireless digital signal
►Support loop recording
► Compatible with Furrion Pre-Wired
► Mirror and flip image
►Parking Assist Line
► Easy to install
► IP69 Waterproof
► Support cycle record
► Support up to 1-4 cameras at the same time
7 -inch HD 1080P touch screen
With HD 1080P resolution system, the digital high -definition image processor HD image will make you more confident and safer when reversing
Recording and Playback
►FHD DVR system, you can loop video, capture along the way,
► Loop recording and local playback make it a dashboard camera.
►SD card saves evidence to protect your rights. (Note: SD card not included)
Guide Lines ON/OFF
► Parking assist Guide Lines On/Off
► Cover the most of dead spots
► The guide wire can quickly turn it on and off according to your needs
Night Vision
The RV spare camera system makes your driving safe. The camera allows you to see around your RV to reduce the blind spot and make the reverse easier and safer.
Super Waterproof
►Durable, waterproof camera that works in any weather. Great for everyday use
Backup Camera Bracket Adapter
► Suitable for the vehicle pre-Wired for Furrion
►The newly upgraded dual upgrade with Bluetooth dual RV backup backup camera, with monitor, power, gearbox distance, stability, durability at least 50 %. The vehicle spare camera can send 1080P video to the display through a stronger signal. The unique dedicated digital signal antenna design and the latest digital signal chip area reached 984 feet, and worked normally within the range of vehicles below 320 feet.
►IP69K waterproof level: Bluetooth spare camera uses the latest sealing technology. The wireless spare camera is IP69K waterproof. Whether in hot and cold weather, it can also be extreme temperature of -23 ° F to 179 ° F. With 18 infrared lights. The screen made by IPS panel allows you to see clear pictures at any angle without reflection or blurring
►Rearview mirror camera with a large HD 1080P 7 -inch monitor: use 1080P CCD image processing chip, the image can be flipped between the mirror (rear view) and the surface (front view). The wireless spare camera system can provide you with 1080P HD images during the day, bright and clear images at night. The 24 -hour clear field of vision is to you. RV backup camera built -in record function and cycle record
►[Easy to install]: Bluetooth wireless digital spare camera and monitor. The spare camera and camera are used together by wireless Bluetooth digital signals, which can make installation and use very convenient. You don’t need to worry about the wiring and installation between trailers and trucks no longer affect your trailer
►4 channel monitor system:. Support 4 wireless RV cameras and recording at the same time. Automatically save videos to prevent it, this backup camera system contains 1-fill screen mode, and the upgraded monitor can switch dual/four-screen screen. You can add 2 cameras to the camera, and you can play videos on the monitor.
►[Warranty Service] 24 hours of online customer service, 30 -day refund guarantee, 2 years of maintenance and lifelong support for sales services. If you encounter any problems or help during use, please contact us first. We will always provide you with high -quality services and solve the problem for you.
