Price: $139.98
(as of Sep 18, 2024 23:15:18 UTC – Details)
DoHonest S21 Wireless RV Backup Camera Can Be Add up to 4 Cameras
This camper backup camera wireless system is a better choice for RV travel lover. It can be used for safe reverse or driving monitoring.
RV Rear View Camera Easy to Install How to install the monitor?
We provide two brackets for the 7 Inch monitor. One is a U-shaped bracket. You can fix the display on the dashboard. The other is the suction cup mount. You can fix the monitor to the dashboard or windshield. How to install the camera?
The rv camera is an universal camera, which can be used for general installation and also for prewired of Furrion installation, which takes about 30 minutes.
HD 1080P RV Back Up Camera for Travel Trailers
Whether during the day or night, you can get 1080P high-definition images, making driving hassle free for S21 back up camera for truck. rv
1 Strong Signal 2 No Delay 3 Loop Recording 4 Support 4 cameras 5 Touch Button
1 Color Vision Day Night
2 IP69 Waterproof Camera
3 DIY Guide Lines
4 Image Flip
5 170° Viewing Angle
Multi-Purpose Work as Reversing Assistant
Replace of the Side Mirror
Work as Monitoringcam
Work as Front Cam
Towing a Trailer
Towting a Ttrailer
Vehicle Backup Cameras System We Recommend
Supported channels
4 channels
Supported channels
4 channels
Supported channels
4 channels
Cameras included
1 camera
Cameras included
2 cameras
Cameras included
1 camera
Function
Recording; DIY Guidelines; IP69 Waterproof; Infrared night vision
Function
Function
Simple to Install and Easy to Use: rv backup camera wireless has a lightweight, all-in-one design that significantly reduces maintenance costs. It requires no complicated wiring and is plug-and-play, making it easy for even a novice to connect it to a Furrion pre-wired system in less than 10 minutes. rv camera system wireless features the latest capacitive touch-button sensors for easy operation, making it convenient for aging parents to use while traveling.
1080P HD Night Vision Display: trailer backup camera adopts CMOS optical signal sensor, ultra-high definition lens and F2.0 large aperture with precise continuous autofocus system, which can restore the received image 1:1. The infrared function of the wireless backup camera automatically turns on when driving at night. With the assistance of 9 night vision lights, the RV camera can capture ultra-high definition images and details in the darkness of the night to protect your night driving.
Powerful Wireless Digital Signal Transmission: RV rear view camera system is equipped with a state-of-the-art 2.4GHz band digital signal transmission module and an intelligent processing unit that enhances system security and stability. It still works efficiently and stably in extreme weather. back up camera for truck. rv has a transmission range of up to 320 feet in open areas, so you can install the camera anywhere in your car without worrying about signal delays or interruptions.
HD 4-Channel Monitor: The i.MX series chip built into the trailer camera system wireless provides better performance for the monitor. When the camper backup camera is turned on, the monitor can quickly capture the signals from the camera. The four HD channels can perfectly display the images from the camera, thus providing drivers with all-around monitoring, and you can see horse trailers, RVs, boats, etc. through the monitor while driving.
IP69 Rated Wateproof Camera: Backup camera wireless is made of aluminum alloy shell with special glue potting and integration process, which ensures that the camera’s waterproof rating reaches IP69, which is 90% more durable than plastic cameras and greatly extends its service life. Expensive materials and unique design process will provide security for your travels, it will never suddenly strike and abandon you on vacation like ordinary cameras.
7″ Narrow Bezel Monitor and ABS+PC: 7″ rv backup camera wireless with monitor features a narrow bezel design that reduces the space taken up by unnecessary bezels, providing a wider field of view and a better visual experience. The exterior of the monitor is made of ABS+PC material, so the monitor is extremely strong and heat-resistant, even if the monitor is left in the car for a long time under the high temperature and hot sun in summer.
Video Recording Function: HD recording and playback function of wireless backup camera for rv is the same as that of the car recorder, which can be used to record unexpected accidents during driving, or to record the scenery during the journey, and the camera can be used as an outdoor security camera when camping outdoors to monitor everything around the RV and ensure camping safety. The loop recording function of the camera provides favorable help for real-time video recording.
Professional Customer Serviece and 2-Year Warranty: wireless reversing camera for RVs, Fifth Wheels, Trucks, Trailers, Campers, Boats, Trucks, Tractors, Buses, and Other Vehicles DoHonest offers lifetime technical support and 2-year replacement warranty for RV Reversing Cameras. If you need help, please feel free to contact us and we will do our best to serve you.
