RV Backup Camera Wireless Easy Hookup: Plug and Play for Furrion Pre-Wired Mount Recording 4 Channel 7” Touch Key Monitor HD 1080P Trailer Truck Camper Fifth Wheel Rear View Camera DoHonest S19
Price: $99.99
(as of Sep 19, 2024 05:00:26 UTC – Details)
RV Backup Camera Wireless System for Large Vehicles BACKUP CAMERABACKUP CAMERA
RV Backup Camera Systems Wireless Easy to Install BACKAUP CAMERABACKAUP CAMERA How to install the monitor?
We provide two brackets for the 7 Inch monitor. One is a U-shaped bracket. You can fix the display on the dashboard.The other is the suction cup mount. You can fix the monitor to the dashboard or windshield.
BACKAUP CAMERABACKAUP CAMERA How to install the rv camera?
DoHonest S19 trailer camera is a universal camera, which can be used for general installation and also for prewired of Furrion installation, which takes about 30 minutes.
BACKAUP CAMERABACKAUP CAMERA Recording and Playback
Loop recordking & local playback make it be the dash camera. ( SD card NOT INCLUDED ). we recommend it’s best to use 32 GB or 64 GB SD card.
BACKUP CAMERA BACKUP CAMERA Good support
As a branded seller, offering support and 24-month replacement service
BACKAUP CAMERABACKAUP CAMERA Setting
According to your favorite habits, you can freely adjust the brightness/contrast/hue.
BACKAUP CAMERABACKAUP CAMERA 170°Wide View
DoHonest S19 trailer backup camera gives you visibility all around your RV to reduce blind spots and makes reversing easier and safer.
RV BACKAUP CAMERA BACKAUP CAMERA BACKAUP CAMERA BACKAUP CAMERA BACKAUP CAMERA
1 Strong Signal 2 4 Video Channels 3 Easy to Use 4 DIY Guide Lines 5 Touch Button
1 Infrared Night Vision
2 IP69 Waterproof
3 2 Brackets
4 Durable Performance
5 Flip Image
1 Towing a trailer
2 Long-term Monitoring
3 Parking Safety
With the latest digital signal chip and a unique dual antenna design, the DoHonest rv backup camera wireless sends high-definition 1080P videos to the 7 inch screen through a strong signal. You won’t have to worry about interference or delays, as the rv backup camera wireless with monitor signal can extend up to 500ft in open areas and 320ft in vehicles.
Equipped with a 4 way DVR video input, wireless backup camera for rv can accommodate up to 4 cameras, you can watch split/full/quad screen modes. Wireless trailer backup camera as a smart highway back/front observation tool for real-time driving security.
The furrion backup camera for rv comes with an extra bracket adapter and pigtail wire for Furrion pre-wired systems. The side view mount can be added to use the wireless rear view camera on the side. Equipped with 11 IR infrared night vision LED lights, wireless rv backup camera can transmit real and vivid images during the day and also real-time color images at night.
The DIY guide line is your powerful assistant when reversing, this trailer camera system wireless allow you customize and adjust the guide line depending on the installation position to fit the parking spot.Designed with an IP69K waterproof wireless rv camera security system , the trailer backup camera wireless can be installed anywhere near the running or reversing light.
With a 170-degree viewing angle, S19 wireless backup camera for trailer is easy to hook up and use for vehicles, such as cars, suvs, semi-trailers, box trucks, campers, 5th wheels, travel trailers, buses, motorhome, towing a boat,horse trailers, tractor and RVs expressing versatility.
