Price: $269.99
(as of Aug 30, 2024 07:15:19 UTC – Details)
RV Backup Camera System with 10.36 Inch Monitor for RV Truck Trailer Bus Semi Truck
It has a large 10.36 inch screen and a touch screen, making it easier to operate than pressing a button Compared with a “wireless” backup camera system, The wired RV camera system can provide you with more stable signal transmission and real-time image without lag. Adopting the latest infrared LED lights, you can get a bright & clean view even in complete darkness. The 360-degree view from the front & rear & left side & right side view camera enables you to drive with more safety. Adjustable parking assisting line enables you to adjust the grid line according to different car models & different parking positions, making it easier to reverse. With the full glued tech and unique waterproof cover, the backup camera with monitor system is capable of running well and long in all types of bad weather. Using a 12-36V power supply, the vehicles camera system is vehicle cameras system is compatible with any vehicle, such as an RV truck trailer camper boat travel trailer bus tractor, etc. Video recording and video playback are supported. Long time video recording can be performed under normal power state, and the recording time is optionalWith parking monitoring function, you can continue to record camera images even if the parking monitoring function is turned off after settingWith more entertainment functions, you can connect Bluetooth to play Bluetooth music, or plug in a USB flash drive to watch movies or other videos.
The Monitor Support Four Channels
Built-in18 IR LED lights, good performance in day and night.See clearly even in poor lighting conditions.Support to display single camera picture or multiple camera picture at the same time, when you need to reverse or turn will automatically switch to the corresponding picture
Built-in Bluetooth function & FM Transmission
With the built-in Bluetooth function, you can answer phone calls & play music on the 10.36-inch monitor via Bluetooth.Support FM wireless transmission and AUX cable transmission, and enjoy the original car audio
Adjustable Parking Assisting Grid Line
You can adjust the parking assisting grid line on the full touch screen so that you can park/reverse easier and safer.
IP68 Waterproof
With the 4 layers of sealed glass lens, full gluing tech & unique waterproof cover, the front view camera & side view cameras & rear view cameras can work great in all bad weather like heavy rain.
DVR & Loop Recording
Built-in DVR recording and loop recording functions enable you to record 4 channels continuously. You can check the recorded video locally on your monitor.
【10.36-inch display】 10.36-inch touch screen allows us to observe 100% of the road. Bigger screen for safer driving. 4 split screens, 4 channels, 4 different angles help us get a 360 degree view. For rear, parking, front, side, left, right, hitch, and turn signal viewing.
【Bluetooth Hands-Free Calls, FM Radio】RV Backup Camera System with built-in Bluetooth and FM Radio makes stable and clear phone calling, wireless Bluetooth audio streaming. FM radio with 18 preset stations, users can adjust radio frequency to get real-time news, music, sports etc.
【IP67 Waterproof Cameras】Using full-sealed and glue-glued tech, RVInWest side view/front view/rear view camera can work great on all bad weathers. With additional waterproof covers protecting the connections, you do not need to worry about rust.
【DVR Recording + Local Play Function】The monitor can record video from the 4 cameras, so you can play the stored video on the monitor to show video proof to police in time if necessary.
【4 Split ISP HD Touchscreen Monitor】- Wide 10.36″ Screen. Backup camera system supports quad view display, a total of 4 video inputs from the front and rear cameras and 2 side view cameras can be displayed on the screen. 4 split screen, 4 channels, 4 different angles help us to get a 360° view to make driving safer.
【Easy to Install】This wired RV camera system ensures stable signal transmission, with a single power cable supporting the entire system. Installing the camera is easy, just connect it to the extension cable on the monitor.
【Flexible Vehicle Compatibility】- Voltage Range From 9-36V DC Power to accommodate a wide variety of vehicle as RV Truck Trailer Class Box truck semi truck Travel Trailer Horse Trailer Bus School Bus heavy duty Camper Tracto
