Price: $279.99
(as of Jul 27, 2024 05:15:33 UTC – Details)
7 Inch 1080P HD 4 Split Backup Cameras System With DVR Recording Function
DOUXURY Backup Cameras + 7 Inch 1080P HD Monitor System for Cars Truck Pickup Trailer Camper Bus RVs 5th Wheel
Why is DOUXURY backup camera worth your choice?
1. 7″ 1080P LED Monitor: The larger screen saves you from having to stare at the screen, providing more view for your safe driving.
2. 1080P HD Image: Provide you clear sharp pictures to make sure 100% safety when you are driving at day and night.
3. Built-in DVR Recording Function: Recording in loop, 24 hours recording to avoid any scam/theft.
4. No Signal Problems: Compared with wireless backup cameras, the DOUXURY wired backup camera system has no problems such as signal interference, poor signal, signal lag, etc.
Backup Cameras System for RVs Pickup Truck Trailer Bus Camper Boat
Super Night Vision
18pcs + 10pcs IR LEDs brings you bright and clear images at night, offer you stable image day and night. Give you more safety.
IP69 Waterproof Level
Adopting multiple glue sealing tech, the backup camera with the good IP69 waterproof performance. Also can withstand extreme temperatures from -4℉~149℉.
360° without Blind Spots
4 cameras give you the all view of your vehicle. Remove all blind spots, even if a small child is behind your giant truck, it is safe enough.
DVR Rcording Function
Built-in DVR recording function. The video data is loop recording and stored in the SD card, maximum supports 128G SD card. Support local playback function.
Parking Assist Line
Backup assist line give you a smoother driving and backup, never look back while you back up your vehicle. Protect your health and safety.
High Vehicle Compatibility
For RVs, Trucks, Bus, Vans, Trailers, Campers, Tractor, Pickup, 5th wheel, Motorhomes, Heavy Box and ect. 12-36V DC power supply.
4.0 out of 5 stars
147
4.0 out of 5 stars
147
4.3 out of 5 stars
506
4.0 out of 5 stars
60
$279.99$279.99 $339.99$339.99 $159.00$159.00 $369.99$369.99
System Type
Wired Wired Wireless Wireless
Screen
7″ HD 9″ HD 7″ HD 7″ HD
Resolution
1080P 1080P 1080P 1080P
Camera Waterproof
IP69 IP69 IP69 IP69
View Angle
170°+ 130°(Side View Cameras) 170°+ 130°(Side View Cameras) 170° 170°+ 130°(Side View Cameras)
Cameras in Package
4 4 1 4
Additional cameras that can be added
0 0 3 0
Other Functions
Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip
DVR Record in Loop
Flexible Vehicle Compatibility: Power supply of 12-24V DC needed can be found in a wide variety of large vehicle as semi-trailer, box, truck, the 5th wheel, trailer, bus, camper.
Built-in DVR Recording Function: 7” large LCD monitor built in DVR recording function. Support to local playback and looping record, you can find the video easily in the monitor.
4 Split 1080p Monitor: Backup camera system supports quad view display, 4 video inputs from a front rear and 2 side view cameras can be shown on screen. Avoid Blind Spot. 1, 2, 5 minutes off display to protect the screen.
IP69 Waterproof Level: Excellent sealing technology, IP69 waterproof level. Safe to use in sunny or rainy days. Withstand extreme temperatures from -4℉~149℉.
Easy to Install: Wired rv camera system without any signal problem. One power cord supports the whole system. The camera only needs to connect the extension cable from the monitor.
Night Vision & Wide View Angle: Sharp clear night vision with infrared LED lights function, 170-degree wide viewing angle removes blind spots and safer driving.
