Price: $269.99
(as of Jul 22, 2024 15:30:23 UTC – Details)
4.2 out of 5 stars
168
3.8 out of 5 stars
18
279
4.2 out of 5 stars
108
4.0 out of 5 stars
59
$269.99$269.99 $59.99$59.99 $134.99$134.99 $298.99$298.99 $369.99$369.99
System Type
Wired Wired Wireless Wireless Wireless
Screen Size
10.36 INCH 7 INCH 5 INCH 7 INCH 7 INCH
Resolution
4k 1080P 1080P 1080P 1080P
Camera Waterproof Level
IP69 IP69 IP69 IP69 IP69
View Angle
170°+ 130°(Side View Cameras) 170° 170° 170°+ 130°(Side View Cameras) 170°+ 130°(Side View Cameras)
Cameras in Package
4 1 1 3 4
Additional cameras that can be added
0 1 1 1 0
Other Functions
Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip
DVR Record in Loop
4K AHD & 1080P RV Camera System: With 4K 10.36 inch 4 split large screen and 4 x 1080P HD cameras. Let you get the clearest picture at all times, avoid the blind spot. Makes our driving safer.
Built-in DVR Recording Function: Supports loop record 4 view cameras at the same time. Saving the 1 min, 5 mins, and 10 mins video automatically according to your choice, you can find the video easily in the monitor.
Compatible & Power Supply: 10.36 inch large monitor system for RV truck box truck semi truck Trailer travel trailer bus heavy duty camper tractor, the 5th Wheel, Motor homes. Power supply: 12-24V DC. Support mirror & flip image.
Great Night Vision & Adjustable Parking Assist Line: With 18 infrared LED lights from the rear/side/frount view backup cameras, give you clear pictures at night. You can adjust the width and height of the guide line as your needs. Touch-sensitive induction, convenient and fast.
IP69 Waterproof & Wide View Aangle: Adopting multiple glue sealing technology, IP69 waterproof level and can work normally in various extreme bad weather. Operated Temperature from -59°F to 176°F.
Easy to Install: Wired system without any signal problem. You only need to provide power to the monitor, and the camera will also receive power at the same time. The camera only needs to connect the extension cable from the monitor.
