RV Backup Camera System Wired Kit, 9″ AHD DVR Monitor with 1080P IP69 Waterproof/Night Vision Rear and Front Camera for RV Truck/Semi Box Truck/Trailer VEKOOTO(N92)
Price: $109.99
(as of Jul 24, 2024 22:30:17 UTC – Details)
VEKOOTO Backup Camera System with HD 1080P 9 Inch Monitor, Wired Backup Camera Kit for RV/Truck/Bus/Semi/Trailer
1212
11
Two different mounts allow the monitor to be mounted in different places.
Surface Mount/Roof MountSurface Mount/Roof Mount
A Must-Have for Your Vehicle
Vekooto Backup camera for a car has two IP69 waterproof 1080p cameras and a 9″ HD LCD, perfect for reversing and driving in limited visibility, like your extra “eyes”. Optional parking guidelines help you park more accurately. Whether it’s a tractor camper, boat, or enclosed trailer, this camera system will be a great assistant to make backing up easier!
More Reliable & Stable Signal Transmission:
Wired backup cameras are more reliable and stable than other wireless digital rear-view cameras, you don’t have to worry about signal disconnection or picture discoloration, or theft.
IP69 Waterproof & Night Vision:
Based on the IP69 waterproof rating and CMOS sensor, the vehicle reversing camera presents an excellent clear image even in rainy weather.At the same time, the IR LED will provide low light compensation to ensure a clear image at night.
Lifetime Tech-Support:
You are always the first for us! We provide Lifetime 7*24 Hours Teach-Support. Please don’t hesitate to reach out to us if any professional help in need. Vekooto is always here to help you.
recordingrecording
1111
11
Loop Recording and Playback
The monitor has a built-in 32GB memory card. Maximum support is a 128GB TF card.
Image Flip Function
Whether it is a Surface Mount or Roof Mount, the correct image can be displayed by simply adjusting the screen position.
Parking Guide Lines
Reversing the screen with a parking line will make parking safer and faster. You no longer need someone to get off the bus to help you see what’s going on and guide you.
Specification of The RV Backup Camera System (N92)
Monitor Size 9 inch Monitor Input 2 Channel Video Input Monitor Resolution 1024 x 600 Camera IR LED 6 PCS Waterproof Level IP69 Camera Materia Metal Cover Camera Real Angle of View 140 Degrees Power Supply DC 9V-35V Image Sensors Color CMOS Camera Operate Mode Button/Remote Control
11
Easy to install and operate
Power supply. DC 9-35V, 1-2A
Connect the red wire to ACC/battery’s (+), the black wire to metal/ground, and the 4-pin connector to the camera as shown in the manual.
The connection of the trigger wire depends on your needs. (If you only use 1 camera, you don’t need to connect the blue trigger wire, connect the camera to CH1)
The package includes all accessories for the system to make the installation easier.
Easy to connect / disconnect
If you have a trailer, you can lay an extra extension cable so that you can disconnect the cable when you don’t need the trailer and connect the cable when you need to use the trailer. No more rewiring.
Package List 9-inch Monitor x1 Camera x2 & 33ft/66ft Cable x2 Upgrade Bracket *4(Camera mounts) Power Cord x1 Remote x1 U-shaped bracket x1 & Lifting Brackets x1 Installation Kit x1 Instruction manual x1
4.0 out of 5 stars
30
5.0 out of 5 stars
4
4.2 out of 5 stars
18
4.2 out of 5 stars
16
4.2 out of 5 stars
9
$109.99$109.99 $99.99$99.99 $79.99$79.99 $99.99$99.99 $269.99$269.99
Monitor
9-inch 9-inch 7-inch 7-inch 10.36-inch
Spilt Screen
Full / Dual Split Full Full Full / Dual Split Full / Dual /Triple / Quad
Record Function
Number of Cameras
2 1 1 2 4
Maximum Number of Supported Cameras
2 1 1 2 4
Installation
Screw fixing Screw fixing Screw fixing Screw fixing Screw fixing
Camera Power Supply
12-24V DC 12-24V DC 12-24V DC 12-24V DC 12-24V DC
Available for Android and iOS
▶Flexible Vehicle Compatibility: Voltage Range From 9-35V DC Power to Accomodate a Wide Variety of Large Vehicle as RV, Truck, Box truck, semi truck, Trailer, Travel Trailer, Bus, heavy duty Camper, Tractor, the 5th Wheel, Motor homes, vans, skid steers, farm tractors, combines, cotton pickers, crop sprayers, bulldozers, snow plows, forklifts, excavators,
▶Two installation methods/waterproof: Monitor can be installed on the dashboard or on the roof inside the vehicle. 6 huge IR lights provide super clear night vision, IP69 waterproof camera (cable interface also has waterproof cover), it can provide excellent clear image even in rainy days. Wired reversing camera kit transmission is more stable, no signal loss at any time.If you need a longer cable, you can contact the seller to get a 32ft extension cable.
▶HD 1080P& Super Night Vision : The upgraded processor makes the image clearer. 6 huge IR lights provide super clear night vision. Wired backup camera kit transmission is more stable, no signal loss at any time.
▶Built-in DVR Recording Function: 9” large LCD monitor built in DVR recording function. Support to local playback and looping record, you can find the video easily in the monitor.
▶Quality Guarantee: Installation manual is included in the package, please contact us if you find the product is substandard or need a different length of cable. 24-Hour Online Customer Service, 30-Day Money-Back Guarantee, 2-years Replacement and Lifetime Support. You are always the first for us.Note: This is a wired connection system!
