Price: $19.99
(as of Aug 18, 2024 09:30:26 UTC – Details)
Keep Your Cooler Ice Cold
The RTIC freezer packs for coolers will keep your cooler ice cold with minimal effort on your part. With these ice packs reusable, keep your items cold for longer. Draws out all the heat from regular ice, causing it to block together to prevent melting. The ice packs cooler come in packs of 2.
Just store the ice chest ice packs in the freezer for 4-5 hours before each use. The refreezable ice packs utilize a durable, break-resistant design that also reduces freezing time. Available in Small, Medium, Large, and Extra Large sizes so you can choose the right fit for every cooler. Perfect for travel and storage.
THIS ITEM IS NOT INTENDED FOR USE BY CHILDREN 12 AND UNDER
REUSABLE COOLER ICE PACK – The RTIC refreezable ice pack for cooler will keep your cooler ice cold with minimal effort on your part. The cooler ice packs come in packs of 2.
LONG-LASTING COLD TEMPERATURE – With these long lasting ice packs for coolers, keep your items cold for longer. Draws out all the heat from regular ice, causing it to block together to prevent melting.
FREEZES FAST – Just store the frozen ice packs in the freezer for 4-5 hours before each use. The refreezable ice packs utilize a durable, break-resistant design that also reduces freezing time.
OPTIMAL PERFORMANCE – You can also supplement the reusable ice packs with ice cubes for optimal performance. For maximum block effect, pack the RTIC cold packs for cooler on the bottom of the cooler.
MULTIPLE SIZE OPTIONS – Available in Small ice pack, Medium ice pack, Large ice pack, and Extra Large ice pack sizes so you can choose the right fit for every cooler. Perfect for travel and storage.
