Price: $149.99
(as of Aug 07, 2024 17:15:31 UTC – Details)
10.36 Inch Full Touch Screen RV Camera System – Wiring Instructions
Backup Camera System with Bluetooth Function & MP5 Video Music Playback Function
Other Features of This 4K RV Backup Camera System
DVR & Loop Recording
Built-in DVR recording and loop recording function, enabling you to record 4 channels consecutively.
Adjustable Parking Assist Line
You can adjust the parking assist gridlines on the full touchscreen so you can park/reverse more easily and safely.
High Compatibility
The required 9-36V DC power supply is compatible with a wide range of large vehicles, including boxcars, trucks, fifth wheels, etc.
Color Night Vision
Four 1080P AHD backup camera on the rear/side/front view, give you clear pictures at night.
10.36” Touch Screen
The HD 1080P 10.36-inch full touch screen gives you clear and sharp pictures, ensuring your safety when driving day and night.
IP67 Waterproof
With 6-layer sealed glass lenses, fully glued technology and unique waterproof cover, it can work normally in all bad weather.
🚗Wired Reversing Camera with Stable Signal Transmission: The wired backup camera kit has more stable transmission and will not lose signal at any time. If your wireless backup camera is always intermittent and delayed, a wired camera is a reliable companion for every drive.
🚗Rear View Camera with Parking Guidelines & Image Flip: Reliable and adjustable parking lines and image flip for fast and perfect reversing, even if you sometimes have trouble figuring out the steering, just switch to the “mirror” view on the monitor, making you at ease when reversing.
🚗4 Channel Monitor System & Built-in Bluetooth: This RV backup camera system contains 1-full-screen mode, 2-split-screen mode & 4-split-screen mode. You can choose a full screen or split mode according to your needs. With Bluetooth function, the Roinvou rv camera system enables you to connect your cellphone to the monitor to play music and answer calls.
🚗DVR Record Function & Loop Recording: The rv rear view camera is equipped with a built-in DVR recording function, ensuring that your videos are always at your fingertips. The wired backup camera system will cover the previous video file when the SD card is full, ensuring you never miss a moment with your backup camera. (Included 64GB SD Card)
🚗Parking Monitor & Color Night Vision & FM Transmitter: Parking monitor functions as a surveillance camera system while the vehicle is off. Four 1080P AHD backup camera on the rear/side/front view, give you clear pictures at night. Set the same FM channel on the touchscreen and your car radio (Please avoid using the channel to be occupied by the FM station).
🚗High Compatibility: The required 9-36V DC power supply is compatible with a variety of large vehicles, including semi-trailers, boxcars, trucks, fifth wheels, trailers, and buses. Whether you’re on a cross-country adventure or a daily commute, this wired backup camera system provides unparalleled safety and style on the road.
