Price: $169.99
(as of Sep 06, 2024 00:30:22 UTC – Details)
Bluetooth Backup Camera Wireless can Be Add up to 4 Cameras
How to power the monitor?The first, and simplest, is to use the supplied plugin for the cigarette lighter.We provide a cigarette lighter with switch ON/OFF in the package.The second is to connect directly to the 12 volt power of the vehicle.
Back Up Camera Systems Wireless Easy to Install How to install the monitor?
We provide two brackets for the 7Inch monitor. One is a U-shaped bracket. You can fix the display on the dashboard.The other is the suction cup mount. You can fix the monitor to the dashboard or windshield.
How to install the camera?
The R8 rv/trailer camera is a universal camera, which can be used for general installation and also for prewired of Furrion installation, which takes about 30 minutes.
Gives You Eyes Where You Have None
Large Monitor Gives Crisp and Sharp Images, as well as Smooth Motion Video
Wireless trailer backup camera system just 2 steps to install:
Monitor be powered by the cigarette lighter outlet or Fuse box ACC Radio Ignition switch
Connect wireless rearview camera to continuous power source like tail light running light license plate light for driving use or connect to backup light for reversing use only
Excellent Night Vision: wireless reversing camera with IR lights provide the sharp image and clear picture that works well at day and night
How is the range on the camera to the monitor.
I mounted the camera on the back of my 40’RV so it is probably at least 38’from the camera to the receiver.Between the camera and receiver is lots of metal,wood and fiberglass.On my last trip of 3000 miles,rv camera was rock solid with great video
Does Rohent make a side marker camera that will pair with this unit?
Yes ,this Rohent R8 back up camera systems wireless can be add/pair a side view camera the model#U16 or B0B4B42PD7,total add up to 4 cameras
Will it work without Furion pre wire? I have power to the back with top tail lights.
yes, Rohent R8 rv backup camera wireless will work without Furrion pre wire. This comes with wires for you to splice power from top tail light or any other 12V source you want to
Has anyone used this camera on a roadtrek rv van and where did you mount the camera?
Mount the camera on the back of the towed vehicle so that bluetooth backup camera wireless has a clear view of the road behind it. Probably around 4 feet off the ground in the center of the vehicle.
Will this camera mount on a furrion bracket? My camper already has a furrion mount on the back
Our travel trailer was pre wired for a Furion camera and the adapter and mounting brackets that came with this unit made wireless trailer camera easy to plug right in and mount without any issue.
Reliable signal: Wireless backup camera ensures super stable transmission of HD 1080P videos with a strong signal range of up to 984 ft in open areas and 320 ft within vehicles; Say goodbye to interruptions and enjoy a smooth viewing experience
Crystal clear images: This RV backup camera features an HD 1080P camera for your RV or trailer and a another camera for your truck or car; the Bluetooth backup camera can also be used for siding view or monitoring; both cameras offer a wide viewing angle for maximum coverage
Multi-view options: Wireless back up camera for truck .rv comes with 4-way video inputs (CAM1 CAM2 CAM3 CAM4) and split screen ability; allowing you to watch a single screen, split screen or quad screen; the 7 inch display can be mounted on your dash or in other locations for optimal viewing; you can also flip the image between mirror view and front view with optional backup lines
Easy-to-use and durable: Featuring the newest capacitive touch button; R8 wireless rear view camera is easy-to-use and more durable than traditional buttons; it is compatible with heavy-duty and long vehicles such as RV Trailer Campers motorhomes buses cargo vans box trucks flatbed trucks bucket trucks tractors and school buses
Peace of Mind: Our highly waterproof backup camera wireless can withstand extreme temperatures from -22℉~176℉; ensuring reliable performance in all weather conditions; say goodbye to lens water or fog problems and hello to no-worry driving
