Price: $16.99
(as of Aug 13, 2024 14:30:11 UTC – Details)
ice packs for cooler
cooler ice packs
ABOXOBOG A reusable ice packs are made of high-quality BPA-free materials and are the best alternative to traditional ice cubes, with a cooler, faster and longer cooling effect. Perfect for lunch bags, cooler backpacks, breastmilk bags, work and food delivery, make your food/drink chiller and fresher! Put the ice packs back in the refrigerator after use and they will be ready for your next outing.
freezer packs
Key Features & Specs
Each ice pack size – 9.75 x 9.75 x 1 inches
Included in a set – five corks & one funnel
Each pack need fill in 28 ounces(3 1/2 cups of 8oz)of water
Save more space for your coolers & Extended the food and drinks cooling time.
cooler shock cooler ice packs
Just add water once and return the ice packs to the freezer after using and they’ll be ready for your next outing. Save your money spending on ice cubes.
The inside of the ice pack is filled with a proprietary cooling gel mixture, just add water at home, shake and seal, and then turn it into a solid block after freezing, which creates a reusable ice pack.
cooler ice packs reusable
When paired with a high quality cooler, Aboxobog ice packs will keep your food and drink chilled longer — up to 48 hours for Large and Medium packs, and up to 8 hours for Lunch packs.
Aboxobog vs. Regular Water
Ice starts out at freezer temperature and will warm fairly quickly to its melting point (32 degrees F). Once at melting point, the ice will stay at the same temperature during the whole process of melting. After fully melting, the liquid starts to warm normally again.
Aboxobog ice packs also start out at freezer temperature, and will warm pretty quickly, but it’s melting point is at a much lower temperature — 18 degrees F. During the whole process of melting, Aboxobog stays at this lower temperature. This lower melting point means that when ice begins melting and warming in your cooler, Aboxobog packs still stay cold, even as they begin to thaw.
We recommend 48 hours for large packs, 24 hours for mid-size packs, and 12 hours for lunch-size packs for best results.
Reusable
Colder, Faster, Longer
Great for camping, picnics, boating, fishing, tailgating, and any perishable transport (both personal and commercial), Aboxobog ice packs turn warm drinks ice cold in the cooler without turning your sandwiches soggy from melting ice. After a day of fun, just return Aboxobog to your freezer and they’ll be ready for the next outing.
Choose from two closure types:
Screw cap with cork and included funnel for filling.
Zipper version that’s sealed permanently shut with an iron.
Thin, Durable Construction
Aboxobog’s flexible, multi-layer bags are made with aluminum and polyethylene to keep the contents secure and reinforced with thin nylon to help strengthen the pack.
Measuring about one-fifth the thickness of rigid ice packs, Aboxobog’s thin walls (9.4 mils, or about 0.24 mm) freeze quickly without losing cold-transferring effectiveness.
Medium size ice pack — 9.75 x 9.75 inches
2 medium packs replace 6 pounds of ice
Shipped with dry gel mixture — add water and seal at home
Screw cap closure with cork and included funnel
Each pack requires 28 ounces of water (3.5 cups)
Aboxobog Ice Alternative Outperforms Ice
Aboxobog – Superior Cooling
Aboxobog – Longest Lasting
Aboxobog – Reusable
Aboxobog – Affordable & Convenient
Superior Cooling
Aboxobog’s proprietary cooling gel mixture is more dense than ice and uses a scientific phase change formulation, providing a higher energy concentration for sustained cooling at 18 degrees F
Aboxobog ice packs will pay for themselves in just a couple outings (compared to the cost of 10 to 20 pounds of ice) — and no extra trip to the store.
64
1,058
4.5 out of 5 stars
44
$32.99$32.99 $16.99$16.99
— $36.99$36.99
Leakproof
Lightweight
Package Dimensions : 7.56 x 6.54 x 1.65 inches; 4.97 ounces
Item model number : CMFCZK797439623596
Department : Unisex
Date First Available : March 27, 2022
Manufacturer : FashioDesign
ASIN : B09WKCTCFF
You’ll have enough for all your food cooling freezer packs demand. 4 Pack Ice Packs: Reusable and versatile cooler packs. Each ice pack measures 6.5 x7.5 x 1 inches. Colder than ice at 18° F (-8° C)
Reusable & Safe for Everday: These lightweight and portable freezer packs are made with PET. Easy to clean and reusable, great replacement for traditional ice cubes.
Easy to Use: Before using, add water once using the funnel, shake, screw cap on, & freeze until ready to use. Filling the ice-cold pack is easy freezy, perfect chillers for everyday use.
Safe and Reusable】: Reusable portable ice packs are made of sturdy 100% safe material, easy to clean, and can be used repeatedly. Cold packs for cooler are more practical than ordinary ice cubes.
Chilled Food – Even Without the Fridge: These ice packs will keep your food and drinks chilled when you don’t have access to a refrigerator. Great for freezer-to-lunch bag trips or any occasion – lunch bags, cooler backpacks, breastmilk bags, work, or outdoor camping.
