REOLINK 8CH 5MP Security Camera System, 4pcs Wired 5MP PoE Cameras for Home Security Outdoors, Smart Person Vehicle Detection, 4K 8CH NVR with 2TB HDD for 24-7 Recording, RLK8-410B4-5MP White
Price: $386.99 - $299.99
(as of Aug 11, 2024 19:30:22 UTC – Details)
security camera systemsecurity camera system RLK8-410B4-5MP Targeted Smart Detection for Total Peace of Mind
Reolink PoE Security Camera System Provides you 24/7 Protection in 5MP Super HD
See it All in Stunning 5MP HD Visuals
The cameras capture more details in 5MP HD, 2 times the resolution of 1080p HD. The wired security camera system can record in crystal clear 5MP at 25fps, providing you with some unnoticeable details while maintaining smooth on-screen movement.
Lights out, Vision on up to 100ft
When night falls or the surrounding lights dim, the camera seamlessly switches to the infrared night vision mode. Plenty of LED lights and improved infrared radiation enable ultra-sharp and vivid night vision, up to 100ft long distance. Just rest easy, your property remains under surveillance.
Smart Detection Fewer False Alarms
Compared to motion detection, person/vehicle detection can be more targeted, ignoring trivial moves.
Multiple Alerts Never Miss an Event
Get email/push/buzzer alerts, and check motion events on the FTP later to keep yourself in the know.
Smart Playback Quickly Find and Play Back Important Moments
Find the video you want with the person/vehicle event filter, simple yet highly efficient.
Detect Where You Want See What Really Matters
Customize the motion zone/sensitivity, and set schedules for more accurate alerts and peace of mind.
Multi-User Access Remotely View Your Camera and Share with Friends
Supports max.12 devices to access live feed simultaneously (2 mainstreams & 10 substreams). No fees.
1 Smart Detection 2 Multiple Alerts 3 Smart Playback 4 Detect Where You Want 5 Multi-User Access
PoE: Easy Setup & Stable ConnectionPoE: Easy Setup & Stable Connection PoE: Easy Setup & Stable Connection
Thanks to the Power-over-Ethernet technology, power, data, sounds, and high-definition videos can be stably transmitted at the same time via an Ethernet cable. Even if the Internet cannot be accessed or network outrage occurs, PoE cameras keep monitoring and save recordings locally.
Equipped with a 2TB hard diskEquipped with a 2TB hard disk Expand Up to 12TB to Meet Your Needs
This security camera system has a 2TB HDD pre-installed can keep non-stop recording for 8 days at maximum (the default code rate is 6144kbps) and is scalable up to 12TB. Besides the 5MP cameras included, up to 12MP Reolink PoE and WiFi cameras can be added.
DIY Your Own System About Reolink Complete Security Solution 1 DIY Your Own System 2 Why Reolink 4 Security Solution Expert
Reolink RLK8-410B4-5MP PoE Camera System Specifications
NVR Smart PoE Video Recorder (Model: RLN8-410) Up to 8 Cameras Video Outputs Up to 5MP via HDMI and 1080P via VGA for this kit (depands on the resolution of cameras, up to 12MP supported) Compression Format H.265, H.264 Power over Ethernet Sockets IEEE 802.3 af/at HDD Capacity 1× internal port, 1× external port(External power supply required), 6TB max for each port (12TB in total) Power Supply DC 48V/2A, or DC 52V/2.88A Note Reolink NVR only work with Reolink Cameras(up to 12MP). Cameras in the kit cannot work without the NVR. Note We don’t recommend you add third-party cameras to it since there may be compatibility issues Camera PoE IP Dome Camera (Model:D500) Lens f=4.0 mm Fixed, F=2.0 Image Sensor 1/2.7″ 5MP CMOS (2560 × 1920) Viewing Angle Horizontal: 80°, Vertical: 48° Night Vision Black & White by IR LED,100ft Audio One-way Audio (only audio recording) Working Environment -10°C +45°C (14°-113° F), IP67 Waterproof What’s in the Box? 1 x 8CH NVR with 48/52V Adaptor, 4 x B500 5MP PoE Cameras, 1 x USB Mouse, 1 x 1M Cat5 Cable,4 x 18M Cat5 Cables,1 x 1M HDMI Cable,1 x Quick Start Guide,4 x Packs of Screws and Other Accessories
Find Out Other Reolink PoE Security Camera Systems You May Also Want!
2,517
4.3 out of 5 stars
1,259
1,283
4.6 out of 5 stars
17
4.3 out of 5 stars
116
1,033
605
$299.99$299.99
$699.99$699.99
$959.99$959.99
$543.99$543.99
$1,249.99$1,249.99
$54.99$54.99
$79.99$79.99
Resolution
5MP
5MP
8MP
8MP
12MP
5MP
5MP
HDD Pre-installed
2TB
4TB
4TB
2TB
4TB
HDD Capacity
6TB max Each, 12TB Total
Night Vision
IR Night Vision
IR Night Vision
IR Night Vision
IR/Color Night Vision
IR Night Vision
IR Night Vision
Smart Detection
Remote Access
Channel
8 Channels
16 Channels
16 Channels
8 Channels
16 Channels
Recording Options
Reolink NVR
Reolink NVR
Reolink NVR
Reolink NVR
Reolink NVR
Reolink NVRs or microSD card
5MP SUPER HD & STUNNING NIGHT VISION – Capture crystal clear videos day & night with 5MP super HD cameras. The 18pcs infrared LEDs allow you to get high-quality night vision up to 100ft, helping you to protect your property even at night.
SMART PERSON/VEHICLE DETECTION – The new smart motion detection is supported by this system now. Smart PoE IP cameras can identify people and vehicles minimizing unwanted alerts triggered by bugs or shadows. Configure the type of motion you care and get alerted when you really should.
PLUG & PLAY POE SYSTEM – With a single network cable, you can connect each IP camera to Reolink NVR for both power supply and video transmission, making the installation easy enough for DIY enthusiasts and beginners.
STABLE CONNECTION & DIGITAL SIGNAL – Unlike DVR CCTV camera systems, videos will not lose quality or be destroyed by faulty cables. ENHANCED VIDEO RECORDING – Thanks to the built-in mic of Reolink cameras, the system can pick up ambient sound and help to add another layer of security despite the reliable 24/7 continuous recording.
HDD Storage and Remote Playback – Including a pre-installed 2TB HDD, videos can be recorded and stored for ten days without overwriting occurring. Users can add one additional external 6TB HDD via the camera’s e-SATA port. With the free Reolink app, all videos can be played back through your smart device anywhere, anytime.
