Rear View Camera Kit, Wired Backup Camera System 7 Inch Monitor IP69 Waterproof IR Night Vision 149° View Reversing Camera for Truck/Semi-Trailer/Box Truck/RV(SY01)
Price: $129.99
(as of Jul 22, 2024 04:15:17 UTC – Details)
ZEROXCLUB SY01 Wired Backup Camera System kit ERY01ERY01
ERY01ERY01
ERY01ERY01
ERY01ERY01
ERY01ERY01
If you want to learn more about the instructions before purchasing, please reach us.
ERY01ERY01
If you find that an accessory is missing or damaged, please find us for a replacement.
ZEROXCLUB Wired Backup Camera System: Trusted by Millions of Customers!
The Compatible camera
B082HKJ4XC (Rear View)
B0BG7Z3Z47 (Rear View),B0BG7Y2DD2 (Side View)
IP69k Waterproof
It is tested to withstand the tough conditions in heat, cold, rain, or sun.
IP69k Waterproof
IP69k Waterproof
Camera Number
1
Camera Number
1
Camera Number
2
Clear Night Vision
Equipped with 18 pcs infrared LED and gives 720P high resolution images
Clear Night Vision
Equipped with 18 pcs infrared LED and gives 1080P high resolution images
Clear Night Vision
Compatible Vehicles
RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on
Compatible Vehicles
Compatible Vehicles
【Excellent Night Vision】It makes the image clearer than others. With the same number of pixels, CCD has better imaging transparency and clarity than other sensors, as well as color reproduction. There are 18 infrared lights and digital HD processor to present you with excellent night vision.
【149° Perfect View & Safe Driving】The 149° rear view camera allows you to see a wide range. IPS display has better viewing angle performance. Making your reversing more confident and safe.Exclusively designed for driving. You can give it to your parents and grandparents as a gift. Let them travel safely outside.
【IP69 Waterproof & Support 2 Cameras】With IP69K waterproof design, it is a reliable driving assistant whether it is rainy, foggy or snowy. And this wired backup camera system supports 2 cameras, you can search B082HKJ4XC to add an extra camera.
【 Flexible Vehicle Comatability & Easy Installation】Voltage Range From 9-36V DC Power To Accomodate a Wide Variety of Large Vehicle as Semi-Trailer/Box Truck/5th Wheel/Trailer/Bus/RV/Camper/Truck/Van/Pickup.Easy installation that can be completed in about 30 minutes.If you have any questions about installation, you can contact the seller for support.
【Warranty & Support】One year warranty for this product, we provide the full technical support after selling and any questions about the product, do not hesitate to contact us,we will reply within 24 hours.
