Real NOAA Alert Weather Radio with Alarm, iRonsnow IS-388 Solar Hand Crank Emergency AM/FM/SW/WB Radio, TF Card Speaker, LED Flashlight & Reading Camping Lamp, 2300mAh Cell Phone Charger
Price: $39.99
(as of Sep 05, 2024 10:30:23 UTC – Details)
388 radio388 radio
Real NOAA Alert Weather Fuction
Automatically activate the alarm to inform you of any disaster weather conditions or warnings, when the radio is set at the “Alert” mode. It is a faster method to get warning from radio.
WB/NOAA: 162.400MHz – 162.550MHz (CH1-CH7)
solar radiosolar radio
Support TF Card Player
Support Micro SD card (excluded) work as a MP3 Player, and too many channels to listen. Idea for home, bedroom, car, truck, camping, hiking, patio and garden.
AM: 520kHz – 1710kHz
FM: 87.5MHz – 108.0MHz
SW1: 3.20MHz – 8.00MHz
SW2: 9.00MHz – 18.00MHz
388388
Reading Lamps
Convenient Indoor and Outdoor
11 LED for Reading
Power Bank
2300mAh Rechargeable Power Bank
Solar Hand Crank Radio
Support 3 x AA battery (excluded)
Flashlight
Hand Crank Lantern
Bright 1 LED
emergency radioemergency radio
A REAL weather radio should have automatic NOAA alarm.
NOAA alert alarm function working time: about 50 hours while full changed. It is one more choice to know the hazardous weather.
Wide range of reception: AM/FM/SW1/SW2/7 NOAA Weather channels, enough to receives any news including flood, tornado, thunderstorm, and other warnings
Better entertainment: Support Micro SD card (excluded) work as a MP3 Player, and too many channels to listen. Idea for home, bedroom, car, truck, camping, hiking, patio and garden.
Comfortable: Convenient handle and reading lamp, Bigger size 7.8*5.1*2.6 inch (20*13*6.7cm)..
High capacity: 2300mAh power bank for smart phone. Support 3 x AA battery (excluded). It is used as a Weather radio, can’t work as a professional solar power bank.
Package Informations:
Emergency Lantern *1
USB Charage Cable *1
User Manual *1
1. Real NOAA Alert Weather Radio: Automatically activate the alarm to inform you of any disaster weather conditions or warnings, when the radio is set at the “Alert” mode. It is a faster method to get warning from radio.
2. Wide range of reception: AM/FM/SW1/SW2/7 NOAA Weather channels, enough to receives any news including flood, tornado, thunderstorm, and other warnings
3. Better entertainment: Support Micro SD card (excluded) work as a MP3 Player, and too many channels to listen. Idea for home, bedroom, car, truck, camping, hiking, patio and garden.
4. Siren and Comfortable: Loud Siren; Convenient handle and reading lamp, Bigger size 7.8*5.1*2.6 inch (20*13*6.7cm).
5. High capacity: 2300mAh power bank for Cellphone iPhone (iPhone cable not included) . Can be charged by micro usb port, hand crank and solar panel. Support BACKUP 3 x AA battery (excluded). It is used as a Weather radio, can’t work as a professional solar power bank.
