Randconcept – 95mm Adhesive Dashboard Pad Mounting Disk with Adhesive for Suction Cup Phone Mount & for Garmin GPS Suction Mount | 3.74″ Wide Diameter 2 Pcs
Price: $12.75
(as of Aug 19, 2024 07:00:29 UTC – Details)
Company LogoCompany Logo
Installation:
Clean the dashboard;Remove the protective cover on the base of the disk;Press the disk to the dashboard and leave more than 30 seconds;Attach suction mount on the disc.
Features You’ll Love:
✓ Your phone holder or garmin gps mount will firmly attached to car dashboard no matter how many bumps you hit✓ Now you can change your suction cup to new location with our sticky disc, even from windshield to dashboard.✓ Enjoy stafety driving without dropping suction phone holder or gps mount again!
EBC bannerEBC banner
Making Driving Safer & More Convenient With Randconcept Sticky Pads
Randconcept dashboard pad sticks to Dashboard with high quality sticky gel to get your car phone mount suitable for more smooth or even textured surfaces, since it will help change the mounting surface to the completely flat surface where the suction cup of mount would have the best performance.
flat surfaceflat surface
No worry about suction cup dropping again from leather dashboard surface!
Leather dashboard surface it rough, suction cup always drop during driving?!
3M dashboard sticky disc provides flat mounting surface for your phone holder or garmin gps mount so that they can be firmly attached to car dashboard no matter how many bumps you hit.
tapetape
High Quality Adhesive Foam
[Foam]
3M PE foam adhesive aims for fixing textured surfaces, like leather dashboard.3M VHB is BLACK foam enhanced its stiffness, no dirt will be remained after removed from your car dashboard Not like the WHITE 3M adhesive pad, more than 30% foam residue or dirt remaining after tearing off from dashboard
[Cover]
The cover firm can be teared easily comparing with 3M VHB ‘s cover.
[Adhesive]
3M 4225 adhesive attach firmly to your car dashboard due to its strong sticky materiel.
11
22
33
44
Step 1
Clean the dashboard surface thoroughly with the provided cleaning pad. Make sure there is no dust or debris.
Step 2
Remove the 3M red film from the sticky pad. Make sure the dash surface is flat and clean.
Step 3
Press and rub the sticky pad from the top. Make sure all adhesive area sticks to dash surface firmly.
Step 4
Place and press the suction cup pedestal on the center of the sticky pad. Make sure no air remains.
packagepackage
Package Includes:
✓ Cleaning Pad x2✓ Installation guide x1✓ 3M VHB adhesive sticky Plate x2
Note:
Please note that each pad is one-time use only. Once removed, it may not be reapplied.Please clean the your suction cup with running water and let it air dry before attach to the sticky plate surface.
Product Dimensions ‏ : ‎ 3.5 x 3.5 x 0.3 inches; 1.8 ounces
Date First Available ‏ : ‎ June 4, 2019
Manufacturer ‏ : ‎ Randconcept
ASIN ‏ : ‎ B07SPJ7BSX
Wide compatibility: Adhesive mounting disk fits any suction cup style or accessories mounting within 95mm in diameter suction cup for adhering to dashboards in the market. Our sticky disc is flexible option for carmount sticky pad replacement!
Mounting with smooth and flat surface: Thanks for PVC plate and 3M VBH adhesive, upper part PVC plate provides smooth and flat surface while bottom Sticky 3M PE foam adhesive fixed dashboard textured surface!
No more adhesive separated: The bottom grey color PE foam adhesive is enhanced version comparing with white adhesive in the market. It performs well even in hot and cold weather or climates.
Safe Journey: After suction cup firmly attached with our sticky pad, you can enjoy navigation with smartphone or garmin GPS devices even camera securely on dashboard. No more dropping phone holders or garmin accessories for gps during driving.
At Randconcept we know our customers want nothing but the finest which is exactly what we offer. From using the highest quality materials to using state of the art adhsive disc, we take all the right steps to make sure you get the finest. We’re so confident that you’ll love our sticky pads.
