Price: $79.99 - $59.99
(as of Aug 11, 2024 10:15:15 UTC – Details)
Projector Screen for Outdoor Movie
Projector Screen for Home Cinema
Size Specifications
View size: 106.2 × 59.8 inch
Frame size: 106.2 × 90 inch
Ground reinforcement
In case of light wind outside, the base and bracket can be reinforced to keep stable.
Set of accessories
Straight connecting pipe × 6 ;Bent connecting pipe × 2;Ground nail × 4;
Metal aluminum tube A(87.5 CM)× 3;Metal aluminum tube B(72CM)× 6;
Strong metal base × 2;projection screen × 1;Carry bag × 1
Easy to move
A good helper for travel
Size available
Auxiliary stabilization
Complete accessories
portable
No creases
HD Screen
160° WIDE ANGLE
4.3 out of 5 stars
653
4.3 out of 5 stars
3,847
4.3 out of 5 stars
737
$39.99$39.99 $46.99$46.99 $59.99$59.99
Brand
SKERELL SKERELL SKERELL
Size
80 inch 100 inch 120 inch
Weight
2.8 KG 3 KG 3.5 KG
Highlights
Small and exquisite size gracefully to indoor party Moderate size suitable for indoor and outdoor Larger dimensions give you a wider perspective
Stand
Carrying Bag
【PROJECTOR SCREEN AND STAND】120 inch Portable projection screen, 16:9 format,160° Wide Viewing Angle. The projection screen has made of high-quality polyester spandex material .That offers sharp and high-resolution images,even support Front Rear projection.
【SETUP ONLY TAKES 5 MINS】The projection screen can be set in about 5 minutes without any complicated tools.No screws, no strings,only several kinds of accessory, enough to fastly and firmly set it up.
【CONVENIENT TO CARRY】Rear projection screen with stand has weight of 6 lbs. You can hold it on one hand or put travel bags on your shoulders, easy to carry in anywhere you want and pack away. It easily stowed away in the CAR TRUNKS, Sedan included! That make it easy to travel along with for family trips, camping, or backyard movie night ect.
【DURABLE ALUMINIUM ALLOY FRAME】The foldable outdoor projector screen with unique base of the stands keep stable.Deeper plastic joints can be perfectly insert into aluminum poles with a tight fit to avoid loose.In addition,it comes with 4 stainless steel stakes,and it can be inserted in the hole of the bases when in the lawn,which can improve the stability.
【APPLICATION AREAS】 This projection screen can be used both indoors and outdoors. like camping, backyard movie, home theater, the large commercial activity center, performance entertainment center, even mini drive-in theater etc.
