Premium 1.7L Stainless Steel Vacuum Insulated Coffee Bottle – Double Walled Hot Beverage Thermos – Keeps Drinks Hot for 12 Hours and Cold for 24 Hours – Stylish Silver Household Kettle
Price: $33.99
(as of Sep 05, 2024 00:15:22 UTC – Details)
11
33
Thermal Coffee Carafe/ Tea Pot
In an environment/room temperature of 22℃, filled with 95°C boiling water:
After 6 hours ≥ 80°C; After 12 hours ≥ 70°C; After 24 hours ≥ 56°C
Cooling effectiveness:
In an environment/room temperature of 22±2℃, filled with ice water at 0℃:
6 hours≤3℃
(The above data are test data, please refer to the actual.)
Calibre: 64mm Capacity: 1.7L Inner liner material: 316 stainless steel Shell material: 304 stainless steel Seal material: food grade silicone Material of plastic parts: food grade PP Bottom diameter: 15cm Height: 21cm
11
Our Thermos:
Crafted with high-quality stainless steel, our thermos flask is both durable and safe for your health. The interior is made of 316 food-grade stainless steel and the exterior is 304 food-grade stainless steel, ensuring robustness and long-lasting performance. The BPA-free detachable lid and smooth stainless steel surface make it easy to clean and maintain.
ああ
ss
ss
Quality and Durability
316 Stainless steel Vacuum jug interior and 304 Stainless steel exterior thermal design, allows for maximum temperature retention.
360° Rotating Fixation, No Leakage
Sealing silicone ring with threads, leak-proof. And prevents rotational misalignment.
Screw on the lid in a clockwise direction and fasten the upper lid to prevent leakage.
V-shaped spout design
The coffee carafe with V-shaped spout design makes the water flow more smoothly when pouring. And Make sure the water will not splash when pouring in case of scald.
ーー
Matters needing attention in coffee kettle:
1. Do not place next to a heat source as this may affect the function of use.
2. This product is a water storage jug and cannot be heated, please avoid any form of direct heat, otherwise it may cause damage to the vacuum layer and deformation and discoloration of the plastic parts.
3. For minors, please use with the help of adults to avoid bruises and burns caused by the kettle falling.
4. Do not add dry ice.
5. When cleaning, make sure that the seals and other accessories are intact so that they do not interfere with use.
6. When storing milk, juice or dairy drinks, store them only for a short period of time; prolonged constant temperature storage is likely to cause food spoilage.
7. Please check frequently to see if the silicone seal inside the lid is detached. If it falls off, it needs to be reinstalled to prevent the coffee pot from leaking and causing burns.
8. Do not wash in a dishwasher.
9. Do not use to keep dairy products or baby food warm for long periods of time (risk of bacterial growth).
10. Do not use heating equipment such as microwave ovens to heat products.
11. Do not store carbonated drinks for a long time, so as not to corrode the body of the pot.
ss
ss
ss
One-hand Pressing Design
Simply press the button on top of the lid to open the coffee pot spout for pouring your favorite hot beverage.
Large Capacity
1.7L Coffee Carafe, Satisfy your coffee needs for the day.
Clean the inner pot and all parts with a neutral detergent before use.
Enjoy Your Hot Coffee
It’s vacuum insulation will keep your drink hot and fresh. Enjoy a cup of coffee or tea on the go, at work, or even camping!
33
Cleaning the jug is easy thanks to the smooth, stain-resistant stainless steel surface. The sleek and attractive appearance makes it a great gift for tea and coffee lovers. The one-click, one-handed pouring mechanism ensures no leaks, drips, or spills. The silicone non-slip insulation on the bottom minimizes the risk of the jug sliding and protects surfaces from high temperatures. Choose our vacuum jug for a reliable and convenient drinking experience.
☕️【HIGH QUALITY THERMO BOTTLE】Made of durable and rust-resistant 18/8 stainless steel with a food-grade PP lid.
☕️【Double Wall Insulation】 Keeps your coffee or beverage hot for up to 12 hours or cold for up to 24 hours.
☕️【Easy to Use Coffee Pot】 Features a round touch handle design for one-hand operation and a wide-mouth design for easy cleaning.
☕️【Large capacity】1.7 litre capacity, ideal for serving hot drinks at various events.
🎁【A Great Gift】 Perfect for everyone, as a necessity. Ideal for bedside, restaurant, office, party, camping, travel insulated coffee carafes.
📦️【What You Get】Exquisite packaging gift box for the thermos, beautiful thermos, 60-day unconditional return and refund, 12-month warranty. Precautions: 1. Do not exceed the maximum water level when using. 2. Different monitors will have different colors. If you mind, please buy carefully. Thank you for your understanding!
