Price: $139.99 - $116.22
(as of Aug 17, 2024 04:15:17 UTC – Details)
Powerful and convenient AC power bank
Portable AC power supply meets all your daily charge requirements. The large capacity can give you USB device, tablets, Laptops, smartphones, and home appliances charging.
Match 4 USB ports, dual outputs 110V AC outputs and 1 DC outlet. On outdoors can provide enough power for your LED lights, fans, audio equipment and other devices. Easy to carry, Use A wide range and surge protection. It weighs only 3.3lbs. Compatible solar panel under 100W 13-23V with MC4 connector charge the battery bank.
3 recharging modes. Charging by home adaptor, charging by car charger and charging by solar panel(not included).
Portable power bank with AC Outlet for outdoor camping and home battery backup
You can take it wherever you go and never run out of power. Ideal for travel, home or office use. In Hurricanes, fires and other natural disasters, it is A very good home emergency power supply. Rely on 4 fully visible LED indicators to monitor the remaining battery. The built in fan will out automatically to cool down the battery during charging to prevent this from happening and prolong the overall lifespan of the power bank.
ATTENTION PLEASE
*Not permitted on airplanes.
*To preserve the battery lifespan, please use and recharge at least once in every 3 months.
*Use original or certified charger and cables.
*Avoid extreme temperature.
*Avoid dropping.
*Do not disassemble.
*It’s not waterproof, do not expose to liquids.
*Please dispose of batteries and electronic goods in accordance with local regulations.
Q: Can this battery be discharging while charging?
A: It supports USB outputs through charging, but the 12V DC & 110V AC can’t be used while charging.
Q: What devices can this portable power bank power?
A: Please kindly be noted the AC output can only charge/power your devices that less than 200 Watts, please check out the operating power of your device before use.
Q: How long it can run my exact device?
A: Working time = 146Wh* 0.85 / operating power of your device
For your information, if the power consumption of your device was 20W, The running time will be 146Wh*0.85/20W=6.2 hrs (roughly calculated).
PURE SINE WAVE AC OUTLET
Adopted pure sine wave ac outlet for Powkey 200w portable battery pack with ac outlet, it delivers cleaner and more steady electricity, which helps better protect your electronics.
PRECAUTIONS FOR USE
We cannot make sure for any heating products and so as the reclining furnitures, because the instant power may be much higher than the rated power when they are working, it may be far exceeding the 200 watts that our power station can power.
WHAT YOU WILL GET
portable power station X1
Compact Carry Case X1
DC/home adapter X1
Car charging cable X1
Cigaratte lighter adapter X1
Manual X1
Battery capacity 146Wh DC/Solar Input 15V/2A USB output 4* USBs, 5V/3.1A(max) AC output 2* AC, 110V 60Hz 200w(max) DC output 2V/10A(Max) Recharging time 5~6 hours(DC 15V) Circle life >1000 times to 80% Capacity Size 7.87×1. 8×5. 7 in Net Weight 3.3lbs Package includes 1 x 46Wh power bank. 1 x Carrying bag. 1 x DC adapter. 1 x Car charging cable.1 x Cigaratte lighter adapter. 1 x User manual.
5.0 out of 5 stars
14
4.1 out of 5 stars
372
4.3 out of 5 stars
86
4.1 out of 5 stars
372
$119.99$119.99 $89.99$89.99 $189.88$189.88
— $119.99$119.99
Rated Power
200W /146Wh 100W / 97.68Wh 200W / 146Wh 200W / 146Wh 100W / 97.68Wh 100W / 97.68Wh
DC output
1 x 12V/10A Max 1 x 12V/8A Max 1 x 12V/10A Max 1 x 12V/10A Max 1 x 12V/8A Max 1 x 12V/8A Max
AC output
2 x 110V 60Hz Pure Sine Wave 1 x 110V 60Hz Modified Sine Wave 2 x 110V 60Hz Pure Sine Wave 2 x 110V 60Hz Pure Sine Wave 1 x 110V 60Hz Modified Sine Wave 1 x 110V 60Hz Modified Sine Wave
USB-A output
4 x USB 2.0 5V/3A Max 2 x 5V/2.1A, 9V/2A, 12V/1.5A 4 x USB 2.0 5V/3A Max 4 x USB 2.0 5V/3A Max 2 x 5V/2.1A, 9V/2A, 12V/1.5A 2 x 5V/2.1A, 9V/2A, 12V/1.5A
USB-C output
/ PD65W 5V/3A 9V/3A 12V/3A 15V/3A 20V/3.25A / / PD65W 5V/3A 9V/3A 12V/3A 15V/3A 20V/3.25A PD65W 5V/3A 9V/3A 12V/3A 15V/3A 20V/3.25A
Size
7.8 x 1.8 x 5.7in 7.09×1.77×5.71in 18.1×14.2×2.2in 18.1×14.2×2.2in 17.5×14.2×2.2in 17.5×14.2×2.2in
Weight
3.3lbs 2.2lbs 6lbs 6.2lbs 5.2lbs 5.5lbs
Solar Panel
/ / 40W Solar Panel 60W Solar Panel 30W Solar Panel 40W Solar Panel
【PORTABLE AND MULTI-FUNCTIONAL】:2 x 110V AC power socket(pure sine wave,total max 200W in total, please check the power consumption of your devices before use) / 4 x USB port / 1x DC port. Emergency capable of powering lamps,phones,laptops,TVs,printers,fans,car pumps,toast maker,coffee machine and even mini fridges, all the power is less than 200 Watts, and the heating products should be less than 100W.
【FAST CHARGING 15V/2A DC INPUT】:Recharge the power bank faster than ever with the 15V/2A DC input, only need 5-6 hours to get fully recharged and conveniently monitor the battery level via the 4 built-in LED indicators.
【PURE SINE WAVE AC OUTPUT】:Better than modified sine wave, cleaner current in your hands; it prevents crashes in computers, reduces noises in fans, TV and other devices and it is compatible with more equipment.
【HIGH CAPACITY WITH SUPER SMALL SIZE】: Grade A lithium polymer battery,with only 3.0 lbs net weight(4 lbs gross weight which including all the accessories) and size of 7.87×1.81×5.71in. Ideal power supply for camping or emergency backup.
【QUALITY & CUSTOMER SERVICE】:Contains the highest quality available lithium-ion battery cells.CE FCC ROHS UL MSDS UN38.3, and factory ISO9001 approved. OCP/OVP/Short Circuit Protection/ Auto Power Off Protection.100% Quality Control. We provide 30 days product return with a money-back guarantee and friendly after-sale customer service.
【PRECAUTION BEFORE USE】:We cannot guarantee for any heating products and so as the reclining furnitures, because the instant power may be much higher than the rated power when they are working, it may be far exceeding the 200 watts that our power station can power.
【How to turn on the AC】: Click the Power Button, and then press and hold the AC button for 2 seconds, then the AC outputs will be turn on. The self-cooling fan inside the device will work automatically when the internal temperature is too high. If the fan continues to work for a long time and does not stop automatically, you need to stop using the device and wait for the internal temperature to drop to normal room temperature.
