PowerBear Portable Radio | AM/FM, 2AA Battery Operated with Long Range Reception for Indoor, Outdoor & Emergency Use | Radio with Speaker & Headphone Jack (Black)
Price: $33.98 - $14.99
(as of Aug 20, 2024 02:15:10 UTC – Details)
PowerBear AM/FM Portable Radio
PowerBear AM/FM Handheld RadioPowerBear AM/FM Handheld Radio
Go Beyond Your Power!
PowerBear has been specializing in charging solutions for years. We design each product with the customer in mind and use only the highest quality components.
Technical Specifications:
FM: 80 – 108 MHz AM: 530 – 1600 KHz SNR: 34 dB Power: 2 AA Batteries Dimensions: 4.6 x 2.7 x 1.1 in Weight: 3.7 oz
The PowerBear Portable Radio is the perfect accessory for those far off outdoor experiences that don’t allow for the use of a phone.
Created to be versatile, sturdy, and compact, this radio is built timeless. Easy to access dials and switches allow for you to use the radio with a single hand so that you’re never distracted from the jaw dropping scenery. The powerful speakers let you enjoy this tiny radio with many others, no need to compromise quality for quantity in our sound!
Features:
Long Range Reception Access to AM/FM Radio Built-in Headphone Port Long Lasting Battery Operated Radio Built in High Powered Speaker
With our built-in headphone port you can enjoy the radio without bothering others around you. With the headphone port you can truly enjoy your radio any where at any time.
Long Range Antenna
Our radio is built with a long range antenna that will keep you connected to your local radio stations all the way out in nature. Never miss a beat even while you’re out far far away!
FM/AM Switch
Tune in to all your local AM and FM stations for news, live baseball games, talk radio, all styles of music, and more. The range for the radio is: FM is 80 – 108 MHz while the range for AM is 530 – 1600KHz.
Portable Compact Design
Designed for travel, the radio is built compact. The lightweight sturdy materials allow for easy portability. The radio dials, switch, antenna, and headphone port are placed so that they are easily accessed without being cumbersome.
PowerBear Portable Handheld AM/FM RadioPowerBear Portable Handheld AM/FM Radio
PowerBear Portable RadioPowerBear Portable Radio
Small, compact and easy to use design: Powerbear’s handheld radio was designed to be an on the go-the-radio that is small enough to be with you all the time. Its dimensions are 4.6 x 2.7 x 1.1 inches and it weighs 3.7 oz
Portable FM/AM Radio stations on the go: looking to stay up to date with the ball game or looking to get the latest news? Rest assured, the Powerbear radio will be with you wherever you go, so you can tune into you favorite radio station any time
Perfect for camping, severe weather (hurricane) or power outages: When off the grid, it can be a stressful time when you’re not in the loop of your local radio stations giving the latest update on the weather. With Powerbear, you can get all your local radio stations right from the palm of your hand.
Lasts over 800 hours on one set of batteries. Unplug from the world around you and know that Powerbear radio will still work. This battery powered radio uses 2AA batteries (not included) to be reliable and durable. Pack it and know it will be there and last as long as you need.
Earphone/headphone compatible: Looking for discreet listening? Powerbear radio allows you to get all your FM/AM stations with the convenience of your headphones. Simply, plug in any headphones with a 3.5 millimeter jack for privacy as you listen on the go
