Portable Solar Generator 600, 600W Mobile Lithium Battery Pack and 120W Solar panel with 2 x 600W AC Outlets & 3 x DC Outputs & 1 x USB-C PD 65W &1 x USB FAST Charge for outdoor camping black
Price: $659.00
(as of Aug 17, 2024 15:15:23 UTC – Details)
SOLAR GENERATOR600-A11SOLAR GENERATOR600-A11
SOLAR GENERATOR600-A12SOLAR GENERATOR600-A12
SOLAR GENERATOR600-A13SOLAR GENERATOR600-A13
ENERGY SPRITE 600-A2ENERGY SPRITE 600-A2
ENERGY SPRITE 600-A3ENERGY SPRITE 600-A3
ENERGY SPRITE 600-A4ENERGY SPRITE 600-A4
INPUT & OUTPUT
2*AC outputs1*PD 65W USB-C port1*Quick Charge 3.0 output 18W1*USB-A output 5V/2.4A1*Car output 96W2* DC output 96W1* DC input 1* SOS lamp
NOISELESS Solar Generator
Less than 15dB.
PORTABLE SOLAR GENERATOR
1×ENERGY SPRITE 600+1×SOLAR SPRITE 120;Size: Power station (10.82×6.69×8.46 in / 275*170*215mm),Solar Panel(10.82×6.69×8.46 in / 275*170*215mm)Weight: Power station (11.9 lbs/ 5.4 kg),Solar Panel(9.59 lbs/ 4.35kg)
AUTOMOTIVE Lithium-ion Cell
Service life >15 years.
SAFTY & RELIABILITY QUALIFIED
FCC,CE,PSE,UN38.3,MSDS,UL,IEC62133 Qualified.Upgrade Battery Management SystemOver-current ProtectionShort-current ProtectionOver-discharge ProtectionOver-charge ProtectionOver-voltage ProtectionThermal Protection
SOLAR GENERATOR600-A17SOLAR GENERATOR600-A17
FAQs
Q1: Can SOLAR GENERATOR 600 be charged while in use?
A: YES, It is a solar power station and support pass-through charging.
Q2: What devices can the SOLAR GENERATOR 600 POWER?
a. Devices with power consumption of less than 600W.
b. Devices cannot be used if they consume peak power of more than 1,000W on startup.
Q3: Why does it make a slight sound when in use?
A: The SOLAR GENERATOR 600 adopts an air-cooling system with a built-in fan for heat dissipation. A slight sound is normal when in use.
Q4: Is it normal for the charger to heat up when charging?
A: The charger heating up is a normal phenomenon. It is a standard charger in line with the national safety standards and safe to use!
Q5: How to know the working times for my device? Why does the duration of some devices deviate from the actual usage data?
A: Working time = 540Wh* 0.9 / operating power of your device. The duration of our equipment is based on laboratory data, and the duration of specific equipment usage may vary.
Q6:Does SOLAR GENERATOR 600 include a built-in MPPT controller?
A: All MOLNK power stations and solar generators have a built-in MPPT controller.
SPECIFICATIONS
Capacity 540Wh Battery Lithium-ion Battery(automotive level) AC Output 2*110V,600W,Surge Power 1000W DC Output 1*12V Car output 96W,2*12V DC output 96W USB Output 1*PD 65W USB-C ,1*USB Quick Charge3.0 (18W),1* USB-A(5V/2.4A) DC Input 8mm ,12V-30V(100W Max) Weight 11.9 lbs,5.4 Kg Dimension 10.82×6.69×8.46 in / 275*170*215mm Operating Temperature 14-104F(-10℃ -40℃) Recharging Temperature 32-104F(0℃-40℃)
4.3 out of 5 stars
8
4.6 out of 5 stars
7
4.6 out of 5 stars
7
— $359.00$359.00 $399.00$399.00 $659.00$659.00 $659.00$659.00
Phone(9Wh)
7 Charges 41 Charges 55 Charges 104 Charges 55 Charges 104 Charges
Drone(45Wh)
1.5 Charges 8 Charges 11 Charges 21 Charges 11 Charges 21 Charges
Light(12W)
5.5 Hrs 29 Hrs 39 Hrs 78 Hrs 39 Hrs 78 Hrs
Camera(20Wh)
3.5 Charges 20 Charges 26 Charges 47 Charges 26 Charges 47 Charges
Laptop(90Wh)
0.5 Charges 4 Charges 5.5 Charges 10.5 Charges 5.5 Charges 10.5 Charges
CPAP(40W)
– 10 Hrs 13 Hrs 23.5 Hrs 13 Hrs 23.5 Hrs
MINI Fridge(25W)
– 15 Hrs 20 Hrs 37.5 Hrs 20Hrs 37.5 Hrs
TV(65W)
– 6 Hrs 8 Hrs 14.5 Hrs 8 Hrs 14.5 Hrs
Game(100W)
– 3.5 Hrs 5 Hrs 9.5 Hrs 5 Hrs 9.5 Hrs
Projector(100W)
ENDLESS SOLAR POWER: The SOLAR GENERATOR 600 bundle 1x 600W Power Station with 1x 120W Solar Panel,it can be fully charged with solar panel in only 8 hours, and support pass-through charging while in use,allows you to charge away in no time while on the move and off the grid.
MASSIVE CAPACITY: With 600 wattage and 540Wh capacity, this Solar Power station will power your full-size refrigerator, TV ,CPAP,mini cooler, LAPTOP, Fan, and more for your outdoor and home backup needs.
VERSATILE PORTS: Featuring 2* AC outlets, 1* PD 65W USB-C port , 1* fast charge 3.0 port, 1*USB-A port, 1* Car port and 2* DC ports , the power station can recharge itself and charge (up to) 8 devices (e.g.Drones, Macbook, Cameras, etc.) at the same time to satisfy your outdoor needs.
POWERFUL & NOISELESS: The Solar Generator 600 features 2 standard PURE SINE WAVE AC outlets with 600W rated power and 1000W surge power, At a such large capacity, This battery kit optimizd enclosure design will leave you with VERY LITTLE to NO noise.
RELIABLE & SAFE: The Power station pass 1838# safty tests and certified by global ,Its upgraded Battery Management System(BMS)is well designed to ensure the product’s safety, while your devices and appliances are protected while being charged.
WHAT YOU GET: 1* ENERGY SPRITE 600 Portable Power Station, 1×SOLAR SPRITE 120 Solar Panel,1*AC Adapter, 1* Car Charger Cable, 1* User Manual,30* Days Free Refund &3* Years Warranty.
