Portable Self Cooking Electric Lunch Box, Mini Rice Cooker, 2 Layers 4 Stainless Steel Steamer Food Insulation Lunch Box for Home Office Dormitory Travel Outdoor Kitchen Cook Raw Food, 2L/110V/200W
Price: $38.99
(as of Aug 25, 2024 12:00:21 UTC – Details)
NOTE:THIS ITEM IS NOT INTENDED FOR USE BY CHILDREN 12 AND UNDER.
–>Portable Electric Lunch Box Food Heater Portable Food Warmer for Home and office Self Heating Lunch Box.
–>Plug and enjoy a homemade meal how it was meant to be, warm and fresh.
–>Heat up Fast! Ditch that long line wait time. Our portable food warmer lunch ​box can heat up a healthy, hot lunch box meal in no time.
–>Easy to clean, dishwasher safe. High temperature resistant hot food lunch box tray. Have hot food anywhere
–>Large Capacity , 4 removable inner containers separates your different dishes conveniently. The capacity are totally 2000 ML,it’s easy to bring food, vegetables, soup and other foods go to work or trave.
Specification
–>110V /200W, for home/office use
–>2-layer design, can be combined arbitrarily
–>Not only heating, but also cooking
–>Cook rice and avoid heating leftovers
–>Steam heating
NOTE:
–>1. Heating time depends on food types and food mount(PLEASE REFER TO THE MANUAL)
–>2. When the food out from the fridge, the heating time should be extension appropriate.
–>3. If the food has been set aside for a long time, it is suggested to add some water into the food and then plug in to heat so that the food would become softer.
What in box?
–>Electric Lunch Box Food Heater
–>4 removable stainless steel inner pots
–>3.9 FT Power Cable
–>User Manual
♨【Portable Mini Private Meal Cooker/Steamer】: 4 stainless steel bowl and 2 Layers, each is independent and it is convenient for you to clean. It also provides 4 bowl lid to prevent leak, make sure to NOT cover it when cooking or heating. Ideal for cooking rice, steaming eggs, vegetables, meat and more. [NOTE:THIS ITEM IS NOT INTENDED FOR USE BY CHILDREN 12 AND UNDER!]
♨【Food Grade Material】: Our Electric Cooking Lunch Box is made of food grade PP material, inner container is made of 304 Stainless Steel. High quality temperature resistant, non fragile material which is totally nontoxic and healthy. PLEASE CLEAN WITH DISH SOAP BEFORE FIRST USE, THEN ADD 30ML OF WATER TO THE LUNCH BOX TO COOK ALL BOWLS ONCE.
♨【Multifunctional Cooking/Heating Lunch Box】: 4 Stainless Steel Bowl and 110V Office / Home Use Plugs are included. With this lunch box, you can heat or cook your meal at home, dormitory, office or during travel. (It takes about 30 minutes for the food to fully cooked).Ditch that long line wait time.Ideal food container not only for you, as well as adults who are on diet. Cook for yourself and enioy healthy.
♨【Large Capacity】: 4 removable inner containers separates your different dishes conveniently. The capacity are totally 2000 ML,it’s easy to bring food, vegetables, soup and other foods go to work or travel.
♨【Safety Lunch Box for Heating】Safe is the first place. Our Electric Cooking Lunch Box is made of food grade material, Comes with 304 stainless steel removable container which is easy to clean and dishwasher safe. Make sure to add water into the body, because with the anti dry burning function, the machine will power off automatically when the water is running out. If there is water in the main unit, it will continue to cook until the water is dry or manually turned off.
