Portable Projector Screen with Stand, WEWATCH 120 Inch Projection Screen 16:9, 4K HD Rear Front Projections Movies Screen with Carry Bag for Indoor Outdoor Home Theater Backyard Cinema Travel
Price: $59.99
(as of Jul 31, 2024 20:45:12 UTC – Details)
WEWATCH 100 Inch Outdoor Projector Screen With StandWEWATCH 100 Inch Outdoor Projector Screen With Stand
WEWATCH 120 Inch Outdoor Projector Screen With Stand
120-inch movie projector screen with stand, 16:9 aspect ratio, and 160 degrees wide viewing angle. The portable projector screen will become your projector and your best friend. The movie screen is designed to provide clear, high-resolution images, rich colors, and a great viewing experience in a variety of viewing positions. When you use it, you’ll feel like you’re in a movie theater, whether you’re alone or sharing a fun time with family and friends.
WEWATCH Projector Screen with Stand_VSWEWATCH Projector Screen with Stand_VS
HD Surface
WEWATCH projection screens use new technology HD coating and photosensitive coating to ensure better imaging than other screens.
WEWATCH Projector Screen with Stand_SizeWEWATCH Projector Screen with Stand_Size
160° Wide Viewing Angle
WEWATCH 120 Inch has 160° Wide Viewing Angle, large viewing area, you can enjoy watching movies with your family.
WEWATCH Projector Screen with Stand_PortableWEWATCH Projector Screen with Stand_Portable
WEWATCH Projector Screen with Stand_Front and Rear ProjectionWEWATCH Projector Screen with Stand_Front and Rear Projection
WEWATCH Projector Screen with Stand_Wrinkle-freeWEWATCH Projector Screen with Stand_Wrinkle-free
WEWATCH Projector Screen with Stand_DetailWEWATCH Projector Screen with Stand_Detail
Support Front Projection and Rear Projection
HD projection screen also supports front projection and rear projection
Wrinkle Free & Easy to Clean
Outdoor projection screen is made of high quality polyester material, which can effectively prevent wrinkles. Screen does not leave creases when compressed or folded
This large screen projector screen is hand washable, but please dry the screen projector when it gets wet
Unique and Stable Design
Hook and independent opening design, so that the Stand Screen can be stable in both indoor and outdoor
WEWATCH Projector Screen with Stand_Multi OccasionsWEWATCH Projector Screen with Stand_Multi Occasions
4.2 out of 5 stars
1,490
4.2 out of 5 stars
1,490
4.2 out of 5 stars
602
4.1 out of 5 stars
86
4.2 out of 5 stars
602
$59.99$59.99 $54.99$54.99
— $99.99$99.99
— $129.99$129.99
SIZE
120 Inch 100 Inch / / / /
Native Resolution
4K 4K 1920 x 1080 (1080P) 4K Support 4K Support 1920 x 1080 (1080P)
Viewing Angle
160° Wider Viewing Angle 160° Wider Viewing Angle / / / /
Package include
Pole A*4, Pole B*3, Pole C*1, Pole D*2, Corner connector*2, Water bag*2, Stake*5, Hook*9, Rope*2, Screen*1 3 x Pole A, 4 x Pole B, 2 x Pole C, 2 x Corner connector, 2 x Water bag, 5 x Stake, 8 x Hook, 2 x Rope, 1 x Screen / / / /
【Front Rear Wrinkle Free Projections Screen】WEWATCH projection screen with stand uses soft and elastic polyester fiber material, which is thicker and lighttight and ensure no wrinkles after folding or washing. With both front and rear projection function, you can always carry this foldable projection screen, and enjoy movie whereever you want
【160° Wider Viewing Angle】The viewing angle of the this outdoor projector screen can reach 160°. Within this viewing angle range, you can choose your most comfortable viewing angle. Family and friends watch the movie together without being crowded. Big scene and big space, enjoy your movie watching journey
【With Weighted Water Bags & Tether Cords, Better Stability】WEWATCH projection screen have two stand bases with weighted water bags. You can fill with water or sand to add its weight, more heavy water bag can make the projection screen stand more stable. Also, it comes with tether cords for outdoor stability, and metal stakes to keep those cords securely anchored. It’s perfect choice for enjoy movies at home or in the park or while camping with your family and friend!
【Lightweight Portable projector screen with stand】This WEWATCH projection screen with stand is foldable. The size is 30.7” x 6.7” x 4.3”, and weigh is 7.1 pounds. Everything fits so easily into the bag, then put in your trunk, and carried with you
【Easy To Install within 5 Mins】No screws, only several kinds of accessory, you can set it up fastly and firmly. Two people work together can finish assembling within 5 mins. Great for rapidly transfer place with less time. If this foldable projector screens get dirty, you can wash it and then hang it up
【High-Quality Accessory & Professional After-sales Service】This 120 inch Projector screen and stand comes with several Lightweight aluminum poles. It is not easily to be rust or distorted. High-Quality plastic joints can be perfectly insert into aluminum poles with a tight fit to avoid loose. Two base with tripod greatly make the stand very sturdy. Note: please feel free to contact us if you have any problems about our projector screen, we will make every effort to resolve it for you
【Robust Design & Enhance Your Movie Viewing Experience】The screen is fixed by eight plastic movable hooks above the stand, and both sides of the screen are directly inserted into the support tube of the bracket to make the stand more stable. This solid mounting can reduce the impact of wind on the screen as you watch the movie
【Package Included】WEWATCH Projector Screen with Stand 120 inch Package content: Pole A*4, Pole B*3, Pole C*1, Pole D*2, Corner connector*2, Water bag*2, Stake*5, Hook*9, Rope*2, Screen*1
