Portable Power Station,540Wh Backup Lithium Battery, 110V/500W AC Outlet Outdoor Generators,12V DC & USB, USB-C Outputs, Solar Rechargeable Backup Power for Travel Camping Emergency
Price: $152.98
(as of Aug 18, 2024 14:15:15 UTC – Details)
Why Choose Our Power Station?
Why Choose this item?
1. With 3 Ways Input Charging-Home wall AC outlet power, Car cigarette DC 12V/24V power and from 100W-200W 18v solar power panel(Not included)
2. Pure Sine Wave: pure sine wave output operates even the most sensitive electronics, it’s better than a modified sine wave, with Intelligent CPU control mode, Key switch output, LED display, short circuit, and surge protection.
3. Long Back Up Time: About2-4hours(pc+Display). About 180hours(12V led) . About7 hours(Laptop13″) About 14 hours (50W Fan), About 7.5 hours (32″LCD TV), About 27 hours (20W energy-saving lamps). The working time for your device=540wh/the watt of your device
Products Parameters
Capacity: Lithium battery 150000mAh 540Wh
Continuous power: 500W
Peak Output Power: 1000W
Output waveform: Pure sine wave
AC Input Voltage: 100-240V 50/60HZ
AC output voltage: AC110V 60HZ
Output Real power≥87%
Overheat Protection:>65C°
USB Output: TYPE-C+2.4A+2.4A+QC3.0
DC output 1: 12V*2 Outports(4A+4A)+cigarette lighter 12V/8A
Solar input charging panel: voltage 18V 100W-200W (not included)
Size/weight: 10.24*6.7*6.82in/5.5kg(12.13lb)
👍【Reliable Lithium Battery】500W (peak 1000W),540Wh(10.8V / 150000mAh)lithium battery and weighs 13.7lb, powerful enough to charge smartphones (2000mAh) 75 times, laptops (56wh) 9 times, the power station provides overheat protection, short-circuit protection, voltage control, temperature control, and more advanced safety operations.
👍【Multiple Built-in Ports】The Portable power Power up to 9 devices at the same time, including 2* AC Outputs 110V; 1* 18W USB-C Port that charges iPhone, iPad, Galaxy S9, Pixel, and more; 1* Fast Charging USB Port; 2* USB Ports that support 12W per port; 1* 12V Car Port that supports 96W and 2* 12V DC Outputs(5.5mm) that support 48W per port. It can also output power while being charged.
👍【Easily Rechargeable with 3 Ways】(1)Bawaut portable camping generator can be recharged with any compatible 100W or 200W solar panel (panel not included). (2) The power generator can be fully charged in 6-7 hours by car charger. (3) Can be fully charged in 6-7 hours being plugged into the wall outlet.
👍【Power Outdoors】It’s providing outdoor green power solutions for explorers. A reliable, powerful, and portable power station for your upcoming camping, hunting, or fishing trips, No maintenance. No exhaust gas, portable.
👍【Package Detail】You will receive 1* 500W Bawaut Portable Power Station, 1*AC Cable with Adapter, 1* car charger cable, 1*solar panel connection cable, 1* user guide.
