Price: $199.99
(as of Aug 25, 2024 07:30:15 UTC – Details)
What are SBAOH P302 300W/80000mAh Portable Power Station advantages ?
Compact size and large capacity, 296Wh portable all-in-one power station help you be fully prepared for disaster prevention, emergency, power outage, outdoor activities, home and office use at any time. Excellent Safety BMS, equipped with the Excellent Battery Management System (BMS), protects devices through temperature control, overvoltage protection, overcurrent protection, and short circuit protection functions. And detects short circuits and overloads when performing incorrect operations. Supports two-way quick charge for the power station, which can be fully charged in 2-3 hours. Supports USB-C PD100W and USB QC18W quick charge, allow to charge your smartphones and tablets in a short time. Connect the DC and USB-C ports respectively, compatible with two solar panels to charge the power station at the same time. Equipped with 13 output ports, it can charge multiple devices simultaneously to meet the daily needs. Equipped with 4 pure sine wave AC outlets, suitable for household appliances rated less than 300W. Supports simultaneous use of two 12V automotive devices, the max DC output is 240W. 18W high-brightness LED, 4 lighting modes design, suitable for large-area lighting, very suitable for emergency disasters and outdoor use.
18W High-Brightness LED Light
The back is equipped with a high-brightness 500 lumens LED light. Four lighting modes – Weak→Medium→Strong→SOS Flash. It can project a powerful light up to 500 meters, suitable for large-area lighting.
Support Devices Rating UNDER 300W
Compatible with the waveform “sine wave” of household appliances.
4* AC Pure Sine Wave Outlet
4* DC Output 12V/10A (240WMax)
1* Car Output 12/10A (120W Max)
Built-in Intelligent BMS and MPPT Controller
The MPPT Charge Controller generates about 30%-40% more power than a traditional controller through solar power. Protected by Battery Management System(BMS): Overcharge Protection, Over-Discharge Protection, Short Circuit Protection, Temperature Protection, Overcurrent Protection, Overload Protection
Equipped with Fast Charging Technology
Solar Panel(60W) about 5-6 Hrs
Wall Outlet about 4-5 Hrs
Car Outlet about 6 Hrs
Emergency Power Station
Backup battery power supply for light, laptop and phone,etc. Powered generators for home and office use to provide strong backup power in case of emergency power outage.
Compact Size & Larger Capacity
Capacity: 296Wh
Weight: 6.6 lbs
Size: 8.1 * 8.5 * 5.9 in
Suitable for indoors and outdoors.
Product Specification:
Battery Capacity: 80000mAh / 296Wh AC Output (4 Ports): 110V Rated 300W USB Output (2 Ports): 5V / 4A USB QC3.0 Output (1 Port): 5V / 2A, 9V / 2A, 12V / 1.5A USB-C Output (1 Port): 20V / 5A MAX PD100W DC Output (4 Ports): 12V / 10A 120W MAX Car Socket Output (1 Port): 12V / 10A 120W MAX Package Content: 1 x Portable Power Station , 1 x AC Adaptor(AC-DC5521) , 1 x Cigarette Lighter Plug Cord , 1 x Car Cigarette Lighter Socket , 1 x USB-C to USB-C Cable(5A-100W) , 1 x Instruction Manual Tips: The package is not included the PD adapter, if you want to charge faster, it is recommended to purchase a PD 100 adapter to charge this power station.
【80000mAh Back-up Power Supply】SBAOH P302 is equipped with a 296 watt-hour(14.8V 20Ah) lithium-ion battery pack, which features 4* AC outlets(110V Rated 300W – Peak 600W) , 1* PD 100W port, 1* QC 3.0 port, 2* USB-A Ports, 4* DC ports and 1* DC car socket. It provides 13 power output ports to charge multiple devices at the same time, such as laptop, phone, drone, car fridge and cameras, etc.
【AC Fast Charge& Easy to Carry】You can recharge your power station with an AC adapator when at home, driving the car outlet during a road trip or simply use a SBAOH power station. Portable handle makes it easy to carry around for outdoor activities,particularly convenient to carry.
【Excellent Safety BMS】SBAOH power station is equipped with the Excellent Battery Management System (BMS), protect devices through temperature control, overvoltage protection, overcurrent protection, and short circuit protection functions. And detects short circuits and overloads when performing incorrect operations.
【Outdoor Backup Power】Designed lightweight-just 6.6 lbs and has a solid handle for easy to carry. Equipped with an 18W bright emergency flashlight on the back, which can project a powerful beam of up to 500 meters and is suitable for large-area lighting. It is perfect for outdoor camping and disaster prevention. There are 4 lighting modes you can easily switch (weak→medium→strong→SOS).
【What You Get】You will receive 1* Portable Power Station, 1*AC Adapter & Cable, 1*USB-C to USB-C Cable, 1*Cigarette Lighter Plug Cord, 1*Car Cigarette Lighter Socket, 1* User Manual and 12 months of customer service. Any questions, please feel free to contact us.
