Price: $239.98 - $139.99
(as of Aug 26, 2024 01:00:17 UTC – Details)
MARBERO PORTABLE POWER STATION M168
PRODUCT SPECIFICATIONS
Built-In Battery 167Wh(equivalent to 45,000mAh, 3.7V) Full Charge Time with Adapter Approx. 7hrs Adapter Input DC 15V⎓1.5A Solar Panel Input 16.6V~25V⎓1.5A Max 2*DC Output 12V~16.6V⎓10A, 13A Max 3*USB A Output USB1+USB2 5V⎓3.1A, USB3 5V⎓2.1A(Max 3.1A) 1*USB C Output 5V⎓9V 2.1A(Max 3.1A) AC Continuous Output Power 100W(Peak 200W) Bulb Type 1W Ultra Bright LED Flashlight Working Temperature 14℉-104℉(-10℃-40℃) Storage Temperature 14℉-113℉(-10℃-45℃) Product Size(L*W*H) 8.2*3.5*7.4 inches Product Weight 4.8lbs Model MARBERO M168
MULTI-OUTPUT
3 RECHARGING WAYS WITH PASS-THROUGH FAST CHARGING
OUTDOOR POWER SUPPLY & INDOOR BACKUP POWER
ULTRA BRIGHT FLASHLIGHTS
ASSURED & SECURED
MULTI-OUTPUT: MARBERO lithium backup battery pack equipped with 167Wh capacity (45000mAh), 2*USB ports(5V/ 2.1A), 1*QC3.0 USB port (5V-9V/ 2A), 1*USB C port (5V-9V/ 2A, QC3.0), 2*DC ports (12V-16.6v/ 10A), 2*AC ports (110V/60Hz, max 100w, peak 200w). We provide you 45 days replacement or full refund and 12 months warranty. If you have any question, please feel free to contact us and we sincerely offer 24 hours friendly customer service.
167WH CAPACITY: The power station provides larger power capacity, which can efficiently power up the same electronic devices longer. It can fully charge the mobile phone 12 times, the laptop 2 times, the CPAP machine takes about 4 hours(time will be different according to the machine power), the led light is more than 40 hours, and the mini refrigerator is about 5 hours. Applicable for emergency situations such as hurricane emergency, camping off-grid, short blackouts.
3 RECHARGING WAYS: There are 3 ways to charge the emergency battery supply. It takes about 7-8 hours to be fully recharged by AC 110V wall socket; It can be recharged under direct sun light with solar panel (DC 16.6-25V/1.5A Max and sold separately, not included, Solar MC4 Connectors included), also you can recharge it with the car lighter outlet and the cable is included in the package.
WIDE APPLICATIONS: The portable power station supports Qualcomm QuickCharge 3.0 output, support 5V-9V/2.1A max output for smart devices which also support Qualcomm QuickCharge 3.0. Support 5.5mm DC 16V car kits with DC-cigarette lighter adapter, such as inflation, pump, electric wrench, fridge, etc. Limited appliance wattage <100W, such as lamp, electric fan, TV, etc. It can also be used for laptop, camera, cell phone, tablet, radio, USB-powered night light.
COMPACT & LED: The rechargeable power station weighs only 3.6 lbs and a compact handle design makes it easy to take anywhere. Built with white LED flashlight, which could emit 3 lighting modes (steady light, SOS flashing mode) to meet your different needs. Press the light button for 3 seconds to turn on the light, then press again to switch to flash / SOS mode. When you go out camping or experiencing power outages, this power supply can help you.
