Price: $214.99
(as of Aug 26, 2024 01:45:10 UTC – Details)
Durable, Thick and Reliable!
Low Energy Consumption LG Compressor
LG Compressor Makes Efficient Cooling Performance: for the purpose of saving energy, the compressor will stop operating when the freezer is up to the set temperature, and the compressor will restart to operate when the temperature in the box has risen 6℉-9℉.High-Density Foam Insulation evaporator 3D refrigeration technology, the temperature drops faster than others and keeps the fridge very cool even when you turn off the power.MAX & ECO Mode- This function allows the compressor speed to be slowed down to increase operational efficiencies(ECO) or increase the compressor speed to provide ”quick” cooldown times(MAX). The strong LG compressor can make the temperature 12 min to 32℉(0℃) (Left Zone) in max mode.Lithium Battery- that keeps the fridge working anytime and anywhere (10 hrs when fully charged). The battery can easily be charged with a wall outlet or car/truck/RV plug. Supported 12/24V DC and 100-240V AC, or sun solar system. Easily pull-out battery design allows the use of backup batteries.
Go Far Stay Longer
DT-Pro Wireless Fridge designed With an excellent engine configuration, all internal components are designed for heavy-duty resistance.
Reliable Sealing Property Construction: Thick and high-Density Foam Insulation effectively locks the temperature without leaking cool air. Keep the item fresh all the way on your trip.Anti-Shake: DT-Pro portable fridge is designed to work in a tough environment. with shock resistance it can maintain a balance under a 45° tilt angle, so it can maintain excellent performance even on bumpy roads, suitable for off-road vehicles, and is suitable for long-distance travel.Battery Protection: With three levels of battery protection mechanism- Low, Medium, and High, the car fridge can protect your vehicle battery from running out. It saves your time to re-set with memory function for next time.Simple LCD Control Panel & Mobile App: Wireless or Digital control panel. Easily monitor the setting temperature, choose battery protection modes, or change between Max and ECO cooling modes.HEAVY-DUTY CONSTRUCTION: This insulated cooler was blow-molded for added durability.
OFF-GRID Portable Refrigerator
WIFI APP CONTROL CAR FRIDGE
Easy setting control through your mobile device! Show C°/F° Change temperature setting Independent temperature for dual zones Battery powered Real time commands User friendly design
Multifunctional Mobile App Control Control your portable refrigerator with just a touch on your phone
We want to give you more control over managing internal car fridge temperatures while driving or hiking and cannot reach the cooler, now you can monitor and adjust it via your phone app.
DT-Pro has a mobile app supported by Android and IOS for your comfort, allowing you to control the temperature and settings on your portable refrigerator within seconds.
1. Please authorize the wireless connection function and authorization positioning after you complete the App installation and open GPS. Please tell us if you have any difficulties.
2. The car refrigerator can only connect to 1 mobile phone, does not support the connection of two or more mobile phones.
Please note: if you find any damage after receiving the car refrigerator, please find us in time, and we will provide you with free replacement parts.
Extra Large Wheel
Durable 6” large wheels make transportation easy across all terrains.
Dual Zone Compartments
Dual-Zone structure divides the freezer and the refrigerator compartment.
Heavy-Duty Durable Design
Inside is made of aluminum alloy, which can keep the freezing effect to the maximum.
Retractable Handle
Telescopic luggage style handle makes it easy to move without having to lift.
Detachable Rechargeable Battery
The battery has a 10-12hour life to keep the chill going.
takes 4-6 hours to fully charge.
Cutting Board and Cup Holders
USB Charging Port
The USB socket can be used for charging mobile phones, IPAD, and other 3C smart products, and can provide emergency use during outdoor use.
Door-Activated Interior Light
built-in LED lights which allows us to clearly see the food and drinks inside whether it is day or night.
