Price: $86.99
(as of Sep 29, 2024 13:30:20 UTC – Details)
【POWERFUL ENGINE】- The 2-stroke 100CC heavy duty metal engine is powerful and durable.The mode of engine is single cylinder, air-cooling, two strokes.Max speed can reach up to 45km/h,which is the fastest but safe speed you can get.Max Power: 2.3kw/6000r/min.Max Load Capacity: 150KG.
【UPGRADED 2.5L FUEL TANK 】-With a upgraded 2.5L Fuel Tank .The fuel consumption per 100 kilometers is only 3-3.5L,which is super fuel-efficient.Fuel Type: 90# 92# 95#.Mixing Ratio Fuel Oil and Engine Oil:16:1.Please use premium quality oils to prolong engine life. And add some lubricant into the air cylinder before starting.
【COMPLETE ENGINE KIT】- It is equipped with all the needed hardwares that can convert most regular bike into motorized bike.It can fit for most type 26″-28″ bikes with V-frame, such as mountain bikes, road bikes,cruisers.
【RUNS SILENTLY & SAFE】- Chrome-Plated exhaust muffler will give you low levels of noise and vibration,no worry about noise nuisance. Ignition type is CDI Ignition.It uses a safe capacitor discharge ignition method, so you can use it safely.
【EASY TO INSTALL】- With detailed instruction contains every detail of the assembly steps.You just need to follow the installation manual to complete the installation.If you don’t have experienc on installing the motor kit,please search “100cc bicycle engine kit” on youtube before installing.It will help you and solve many problems during installation. It takes about 2-3 hours to complete the installation.
