pecron E3000 Portable Power Station,3108Wh Portable Solar Generator with 6X110V/2000W AC Outlets 1200W Max Solar Input Backup Power for Outdoors Camping Fishing Emergency
Price: $2,199.00
(as of Aug 15, 2024 05:45:20 UTC – Details)
BrandBrand
BrandBrand
E3000E3000
Power anytimes
Power anywhere
Massive Capacity:E3000 Power station With the 3108Wh capacity 2000 wattage rated power(Surge 4000W) , is a good back-up battery use for home and outdoor activities,suah as camping, tourism, fishing, emergency etc
Power it ALL:E3000 has 16 output ports that can run up to 16 devices at a time. Including 6x 2000W AC outlets, 6x USB ports up to PD 100W, 1x Cigar port, 2x DC ports, and 1x 15W wireless charger,compatible with virtually all essential devices
There are four ways to charge the E3000, including AC(home) charging, DC(vehicle) charging, PV(solar) charging, and generator charging. You can charge the unit from different sources at the same time.
Safety & Reliable:Build-in BMS assure the self-protection of short circuit, overload, and overheat. 110V Pure-sine wave inverter make sure there is no damage to your sensitive electronic devices.
What You Get: 12-month worry-free warranty and 24hrs/7d friendly customer service. pecron E3000 portable power station,Accessory Pack,AC Power adapter ,5-Pin Aviation Plug To MC4 Solar Charging Cable*2;Car Charger cable;User manua1.
