P2001 Solar Generator, 2000Wh Power Station with LiFePO4 Batteries, 6 2000W AC Outlets, UPS Backup, Bi-directional Portable Power Station for Home Power Outage, Outdoor Camping RV
Price: $499.00
(as of Aug 10, 2024 22:15:27 UTC – Details)
power station 2000whpower station 2000wh
FFpower Solar GeneratorFFpower Solar Generator
ABOUT US
FFpower is one of the fastest growing energy technology start-ups in China. We launched our first large capacity power plant in 2021. Aiming to provide a sustainable energy solution for individuals to enjoy renewable energy, and we continuously do our utmost to make a great performance efforts to provide mobile power, solar technology.
Choose Your Backup Power
FFpower portable power stationFFpower portable power station
FFpower Most Popular
bp2000 bp2000
bp2000 power stationbp2000 power station
Power Your Life
solar generator 2000wsolar generator 2000w
Power all your need: With 2000-Watt high power output and 2000Wh large capacity, FFpower P2001 can charge large appliances such as air conditioners, washing machines, etc,ensuring your family meet various power needs during unexpected power outages
Discharge and Charge Simultaneously: FFpower is designed to charge and discharge at the same time a,k.a pass-through charging. This means you can have a solar panel or some other power source recharging the FFpower P2001 while another device (cell phone, computer, etc) is taking power from this power station.
Long lasting Lifespan: FFpower is adopt lithium iron phosphate(LiFePo4) as chemistry battery. It has the characteristics of fireproof and explosion-proof, and rated to 3500 life cycles to 70% capacity, the battery lifespan is 7 times than the standard lithium-iron(NCM) batteries
Save your time: P2001 uses a 2000W bi-directional inverter, you will get a fast charging speed while using AC charging cable.The capacity from 0% to 100% can be completed within 2 hours.
Get power energy from Sun: FFpower P2001 is compatible with any solar panels (12-48V, MAX 500W) on the market. We recommend you to use a 200Watt, 24 Voltage solar panel, as you know the solar panels are affected by many factors such as the light intensity and the panel’s angle put on the ground. Please try use the solar panel under the full sunlight to charging, and make sure there is no shadow cast on the panel.
Protect your computer data: P2001 power station equipped with UPS function, once a power outage occurs, P2001 will goes into effect immediately to be able to power the computers and devices, a standby UPS resorts to battery backup power in the event of common power problems such as a blackout, voltage sag, or voltage surge.
