OUPES Mega 2 Solar Powered Generator 2500W with B2 Battery
Price: $3,593.00
(as of Aug 20, 2024 06:30:19 UTC – Details)
12001200
12001200
Solar Generator 1100WSolar Generator 1100W
OUPES Solar Generator 1100WOUPES Solar Generator 1100W
11
22
33
LCD Display Screen
The 1200W camping generator provides an upgraded monitor provides a real-time battery power monitoring system to help you keep track of the power level status. It also provides warning symbols to alert you in unusual charging cases.
Powerfully Quiet
Powerful enough for a CPAP machine, the OUPES 992Wh power station can power it either through the 110V AC Plug or the 12V DC Plug. The silent built-in fan design allows you to enjoy a quiet night during the charging process, which is user-friendly and considerate for some people with sleep problems.
Can not Support Devices over 1200W
Note: OUPES 1200W power generators can only support devices with a rated power not exceeding 1200W, please refer to your device’s specification before using it.
OUPES Solar Generator 1100W,OUPES Solar Generator 1100W,
FAQ
Q1: Once we use this unit if there is an over-voltage will it show the error what do we do to reset it?
A: When the output over-voltage the ports, the overload Protection Switch button will automatically pop out. You need to turn off the power switch button, then turn it on again, just do like this is ok.
Q2: Why does the battery lose power when not in use?
A: The unit may be in standby mode where the power supply, screen, and/or inverter could be using up to 50W. Remember to long press the power button to turn the unit completely off. If the unit loses power when completely off, try recharging it to 100% and use it to 0% two or three times to calibrate the battery. If the problem persists, please contact customer support.
Q3: How long will the power my device?
A: Working time (estimation) = 992Wh* 0.8 / operating power of your device. (0.8=Conversion Rate). The charging time is shown on the product’s LCD Screen, which can be used to estimate the charging time of most appliances with stable power usage.
Q4: Why would the generator fan run on and off if it’s not in use or plugged into anything?
A: The station is Built-in Smart and Silent Cooling Fan, during charging of it, the fan will be automatically turned on when the unit is hotter to maintain the unit, when the temperature drops to a certain level, the fan will be turned off.
Q5: How to choose the solar panel?
A: OUPES has wide compatibility with other brands of solar panels, as long as the combined open rated voltage range is within 12-30V, 250w Max.
Q6: How do we ship OUPES solar generators?
A: Due to the different sizes of Power Stations & Solar Panels, we will ship separately if your order has multiple products including portable power stations and solar panels.
Notes
– When the control buttons are turned on, even if no devices are being charged, there will still be a certain amount of no load power consumption. Therefore, it is recommended to turn off the control buttons after using them to avoid draining power.
– If you feel that the battery drains fast when used for the first time, it is because the display information of the remaining power is inaccurate when the product is activated for the first time. The power remaining will automatically calibrate by discharging the battery to 1% and then recharging it to 100%.
Technical Specification
Capacity 992Wh(32V ; 31Ah); 310000mAh Battery Cell Type LiFePO4 (3600+ Full Life Cycles) 3* AC Output 110V/1200W(Rated); 2200W(Peak) 2* DC Output 12V/10A 2* USB-C Output PD 60W(left)/ 18W(right) 2* USB-A Output 5V/3A;9V/2A;12V/1.5A(18W Max) 1* Car Cigarette Output 12V/10A LED Lighting Full Bright / Half Bright / SOS Flashing Mode Waveform Sine wave Dimensions 12.99 x 8.66 x 11.37 inches Weight 24.25 Pounds
