Oklahoma Joe’s Longhorn Reverse Flow Offset Smoker – 17202053
Price: $771.47
(as of Sep 10, 2024 10:45:14 UTC – Details)
Elevate the classic smoking experience with the large-capacity Oklahoma Joe’s® Longhorn Reverse Flow Offset Smoker. Built with versatility in mind, optional smokestack locations and removable baffles let you choose between reverse flow smoking for additional even heat and smoke, or traditional offset smoking.
TYPE: The Longhorn Reverse Flow Offset Smoker provides the best for you outdoor cooking needs. With optional smokestack locations you choose between reverse flow smoking and traditional offset smoking.
FUEL: Charcoal fuel allows you to grill with high heat or cook low and slow.
SIZE: 751-square-inches of primary cooking space; 309-square-inches of secondary cooking space.
MATERIAL: Heavy-gauge steel construction ensures durability you can trust.
CONTROLS: Professional temperature gauge for accurate monitoring.
FEATURES: Bottom shelf lets you keep cooking utensils and additional fuel close-by and cool-touch handles protect your hands from the heat.
GRATE: Four baffles locked under porcelain-coated wire grates deliver even heat and smoke through cooking chamber.
MOBILITY: Large, wagon-style wheels for easy mobility.
CLEANING: Large charcoal basket provides a more efficient burn, easier tending and a convenient firebox door makes clean-up quick and easy.
WARRANTY: 2 years on all parts
