Price: $28.99
(as of Aug 02, 2024 11:45:13 UTC – Details)
1.Back cushion is ergonomically designed to fit the streamline of your spine curve, contoured design effectively helps realign your back and spine, it can sufficiently alleviate the pain and fatigue of lumbar and vertebra area -Prevents muscle fatigue and tightness in your back -Promotes good posture and proper spine alignment -Relieves pressure points and increases blood flow,support the whole back, especially the low waist and the waist side.
2. Posture correction, The lumbar spine is not good, there are several reasons. Long-term sedentary, tired, lifting heavy objects. Sedentary posture is not right to damage the waist. This lumbar support pillow fit body curve, use it can push you to correct sitting posture.
3.High-density and high resilience memory foam gives you a perfect balance between firmness and softness, contour of your lower back, disperse your pressure,water and heat may destroy memory foam structure, so please don’t wash it, dry it nor expose inner memory foam in the hot sun.
4.The adjustable elastic strap fits any chair and keep the cushion in the perfect position,of course,the back cushion can also be used without the straps when sitting on couches or somewhere else,by putting it behind you and lean against it.
5.Removable Breathable Mesh Cover,Back Support with the Fabric-Mesh breathable cover and hidden zip, easy to disassemble.Just zip off the fabric cover, toss in the wash with your other clothes, and replace when dry. and can be gently washed by hand or by machine.The easy-clean cover means that you no longer need to worry about getting your pillow dirty. Inner memory foam which can not washable extends the durability of foam core.
6.The lumbar support pillow is vacuum packed,so it will puffed up fairly quickly after you open the package,and will return to the original shape within a few minutes.
Dimensions: 18.1 x 15.8x 4.3 inches Item Weight: 1.46 lb Color: Black
100% High Density Space Memory Foam
High density space memory foam core absorb the stress from long sitting, relief the waist pressure.Heat and water heat may destroy its structure,so please don’t wash memory foam inside pillow,also don’t expose to the sun,It is recommended to use after a period of time,wipe clean with dry cloth,and then put it in a cool and ventilated place for a few days.
Improve Posture,Correction of The Spine
Unlike other traditional pillows or cushions that slip and fall out of place or with insides that move around, the memory foam stays put, cradling both sides of your spine without feeling rock-hard. The memory foam is ideal for all-day use, whether driving in the car, traveling on a plane,sitting at your desk, or simply hanging out at home.
Adjustable Freely Snap-On Strap
This back pillow goes wherever you need extra lumbar support. It can be installed quickly with the easy-to-use and adjustable one-clip belt. Simply wrap the straps around the back of whatever seat you’re in and click the strap closed. Disassembly is just as easy.
Removable and Washable Cover
Removable Breathable Mesh Cover-Back support with the fabric-mesh breathable cover and hidden zip, easy to disassemble.Just zip off the fabric cover, toss in the wash with your other clothes, and replace when dry.
Tips:Inner memory foam which can not washable extends the durability of foam core.
More considerate design
Why do you choose Newgam lumbar support pillow?
✔️The lumbar support pillow that sells on market, great majority does not have inner cover,The inner cover to avoid it polluting by sweat and dust,protect your health,soft,light and breathable!
✔️Breathable 3D mesh cover,skin-friendly,comfortable and breathable fabric,moisture absorption and perspiration,soft and delicate touch,heat dissipation.
• • • • • • • • • • • • • • • • • • • • • • • • • • •• • • • • • • • • • • We always believe that good materials can create good quality ! • • • • • • • • • • • • • • • • • • • • • • • • • • •• • • • • • • • • • •
Ergonomically designed to better conform to the human spine curve and correct sitting posture,do good to health. Suitable for all kinds of people:
It has very wide and thick sides on the lumbar bottom, so it can support the low back better.
It’s perfect to use in most office chair,computer chair,desk chair,armchair,gaming chair,executive chair,couch,car seat,suv seats,truck seats,wheelchair and recliner seat,home chair or seat on a bus, airplane or train etc,and perfect for office workers, drivers, teachers, students, people in a wheelchair, pregnant women etc.
Ergonomic and Contoured Design – Our lumbar support pillow could help alleviate the pain and discomfort associated with lower back soreness, injury, chronic condition, or simply add a little more support for those who sit for long periods at work or drive hours-long distances. Its ergonomic design, high-grade memory foam and cooling gel materials, and firm support are all designed to gently hold you in the correct position, alleviating pressure and stress on this sensitive area of the body.
High-Density Space Memory Foam – Firm yet comfortable, lumbar pillow supportive memory foam holds your lower back in the right posture. Unlike other traditional back support pillows or back cushions that slip and fall out of place or with insides that move around, the memory foam stays put, cradling both sides of your spine without feeling rock-hard,The memory foam is ideal for all-day use, whether driving in the car, traveling on a plane,sitting at your desk, or simply hanging out at home.
Quick and Easy Enstallation – This back pillow goes wherever you need extra back support. It can be installed quickly with the easy-to-use and adjustable one-clip belt. Simply wrap the straps around the back of whatever seat you’re in and click the strap closed. Disassembly is just as easy. Newgam office chair cushion is lightweight, ideal for easy transport.
Removable and Washable Cover with Extra Inner Cover- Back support with the Fabric-Mesh breathable cover, easy to disassemble.Just zip off the fabric cover, toss in the wash with your other clothes, and replace when dry. The easy-clean cover means that you no longer need to worry about getting your back support pillow dirty.Extra inner cover to avoid it polluting by sweat and dust.Skin-friendly breathable , Lumbar Support can keep back air circulating well,just makes you feel comfortable all day.
Please noted: This product is vacuum compressed package,it will be expand after waiting a few minutes. Risk-Free Purchase -30 days hassle free return policy,12 months product after-sales support . Let your shopping more assured.
