NETGEAR Nighthawk M6 Pro Mobile Hotspot 5G mmWave, 8Gbps, Unlocked,AT&T, T-Mobile,Verizon International Roaming 125 Countries,WiFi 6E,Portable Device with touch control, Modem Wireless Router(MR6550)
Price: $999.99 - $899.99
(as of Aug 30, 2024 19:00:35 UTC – Details)
Whether you have a food truck, are at a construction site, or are a first responder, you need to count on stable, secure internet access for your business. With M6 Pro, you can avoid slowdowns in crowded outdoor areas with 5G mmWave internet with speeds up to 8Gbps for incredible streaming and fast downloads. Connect up to 32 devices at once for your mission critical communications and real-time collaboration. Your M6 Pro also provides secure, private WiFi connection for laptops, tablets & phones in airports, hotels, trains and other places offering public WiFi, allowing you to conserve mobile data at the same time. Its all-day battery can keep you connected for up to 13 hours on a single charge.   M6 Pro is also the ultimate travel companion for business trips, family vacations and everyday commutes. A new 2.5 Gig Ethernet port provides an ultra-fast and reliable wired connection to power high-bandwidth business critical applications. You can also connect your business with up to 1,000 sq. ft. of WiFi coverage and double the coverage by plugging M6 Pro into wall power.   To make things simple, M6 Pro is unlocked, supports international roaming in over 125 countries and is certified with T-Mobile. Compatible with AT&T and Verizon.
Ultimate versatility with high-performance, secure 5G mmWave internet with WiFi 6E technology at home or on the go
Unlocked and certified to work with AT&T, T-Mobile, and Verizon. Works in over 125 countries and international carriers, keeping you connected around the world. Swap SIM cards and data plans in seconds
Take M6 Pro on the go as a more powerful and secure alternative to a mobile phone hotspot. Connect up to 32 devices simultaneously, get better WiFi performance and stop draining your phone battery
Use 5G WiFi as a primary connection for your home or business. With fast wireless and wired connectivity, you never have to worry about losing internet during cable/DSL outages again
Ideal as a backup solution when you require 24/7 access to connect your home or office network, surveillance cameras and smart home devices
Remove battery and use power adapter to boost WiFi coverage up to 2,000 sq. ft.
Get secure, private connectivity with M6 Pro instead of using risky public WiFi networks where data can be easily compromised
Effortlessly set up, change WiFi settings, share access, and monitor your data usage on the 2.8” color LCD touch screen
Powered by the Qualcomm Snapdragon X65 5G modem – RF System with groundbreaking speeds up to 8Gbps
