Price: $699.99
(as of Jul 28, 2024 14:00:32 UTC – Details)
Experience blazing fast 5G internet with speeds up to 2.5Gbps at home or on the go. The NETGEAR® Nighthawk® M6 Mobile Router features In-Home Performance mode to boost WiFi coverage up to 2,000 sq. ft. at home or, for max coverage and speed, connect M6 to your router or mesh system and use as your primary internet connection for up to 32 devices. Get exceptional performance with fast 3.6Gbps WiFi 6 speeds and 1 Gig Ethernet port for a wired connection to a WiFi router, mesh system, laptop or other wired devices. Reliable and secure, the M6 provides WiFi service wherever you go. The simple-to-use 2.4” LCD touch screen lets you conveniently monitor data usage, see WiFi name/password, mobile signal strength, and manage device and network settings. Unlocked to work on 5G and 4G LTE and with all providers; certified with AT&T and T-Mobile.
Ultimate versatility with high-performance, secure, 5G with WiFI 6 technology at home or on the go
Unlocked and certified to work with AT andT, T-Mobile, and Verizon. Swap SIM cards and data plans in seconds
Take M6 on the go as a far more powerful and secure alternative to a mobile phone hotspot. Connect up to 32 devices simultaneously, get better WiFi performance, and stop draining your phone battery
Use 5G WiFi as a primary connection for your home or business. With fast wireless and wired connectivity, you never have to worry about losing internet during cable/DSL outages again
Ideal as a backup solution when you require 24/7 access to connect your office network, surveillance cameras and smart home devices
Remove battery and use power adapter to boost WiFi coverage up to 2,000 sq.ft.
Get secure, private connectivity with M6 instead of using risky public WiFi networks where data can be easily compromised
Long lasting battery for up to 13 hours on a single charge
Effortlessly set up, change WiFi settings, share access, and monitor your data usage on the 2.4″ color LCD touch screen
Powered by the Qualcomm Snapdragon X62 5G Modem-RF System with groundbreaking speeds up to 2.5Gbps
