Monster Power Grid Portable Power Station 296Wh, 10W Wireless Charging Pad, LED Flashlight, Charge up to 9 Devices, for Outdoors Camping Travel Hunting Emergency, White (22)
Price: $279.99
(as of Jul 30, 2024 23:00:16 UTC – Details)
Power Grid 300 FinalPower Grid 300 Final
Power Where You Need ItPower Where You Need It
Go Anywhere_v2Go Anywhere_v2
Portable Illumination v2Portable Illumination v2
Power DeliveryPower Delivery
Built to Go Anywhere
The Power Grid 300 is the perfect addition to supercharge your weekend trip or your outdoor activities. Built with durability in mind, it has shock absorbing bumpers that can withstand the trials of your outdoor adventures.
Give yourself peace of mind with a built-in LED flashlight. The perfect companion for evening adventures or navigating your home during a power outage. Choose between 3 light modes (Always on, Rapid Strobe Flash, and SOS mode) for both emergency and low light situations.
Power Delivery
Charge high-capacity USB-C devices at top speed with evolved 60W power output. Fast charge your phone, laptop, tablet and any other USB-C devices in less time.
Multi Port v2Multi Port v2
No Devices over 300W v2No Devices over 300W v2
Solar PanelSolar Panel
Built-In Protections v2Built-In Protections v2
Only for Devices Under 300W
Please note that the AC outlets for the Power Grid 300 are optimized to deliver constant power to devices with a rating of less than 300W.
3 Ways to Charge
Not only can the Power Grid charge in wall sockets and carports, but it will also charge with a solar panel (not included) making it extremely useful for camping and outdoor adventures.
Note: Solar Panel Needs To Be Purchased Separately
Protected Layers of Technology
The Power Grid 300 has multiple built-in protections to ensure safety during it’s operation.
Short-circuit protectionOver-current protectionOver-voltage protectionLow voltage protectionOver-load protectionHigh or Low Temperature protection
Technical Specifications
Capacity 296Wh Dimensions 10.4 x 5.5 x 5.5 in / 265 x 141 x 141 mm Weight 7.7lbs – 3.5kg Battery Type Lithium Ion Batteries Inverter Wattage 300W (Pure Sine Wave) Full Charge Time by AC Adapter 8 hours Trickle Charge Car Battery Through the DC Port AC output 1/2 110 Vac/60Hz/300W (Max) (Note: 2 AC Outlets shared 300W Max USB-A Output 1/2 5V/2.4A USB-A Output 3 5V/2.4A USB-C Output 4 60W Power Delivery DC Output Port 12V/10A 12V Cigarette Socket Output 12V/10A Wireless Charging Output 10W (Max)
Versatile Power Source: This portable backup battery power supply allows you to charge up to 9 devices. It comes with an 110W wireless charging pad, LED flashlight, 3 USB-A ports (7.2A shared), 60W USB-C port, 2 AC outlets, 12V DC output, and a 12V car port.
Power Your Day: Regardless of where you are, the Power Grid will keep almost anything powered. You can use it as a battery backup power supply in emergency situations at home, on road trips, camping, hunting and other outdoor activities.
Power Whenever You Need It: One of the most convenient outdoor generators on the market, the Monster Power Station provides a portable charging station and a built-in LED flashlight for use in night time emergencies or during an outage.
Portable and Compact: The Power Grid is small enough to be carried in hand or placed in your car trunk for electric portable power anywhere you go. It’s a perfect portable generator for camping as it comes with an outlet to plug in a mini 60W fridge.
10W Wireless Charging Pad: This portable power supply station can instantly charge your phone or earbuds with fast charging technology. Designed with a charging pad on top, all you have to do is place your device on the pad and charging will begin.
