Price: $14.99
(as of Aug 24, 2024 14:00:30 UTC – Details)
MOMSIV 380ml/12oz Travel Coffee Mug for Car and Outside
Enjoy your coffee time anywhere without worry about leaking
Feature:
1. Keep drinks hot or cold: This coffee cup can keep your beverages hot or cold for up to 6 hours. You can get a fresh drink at any time.
2. Leakproof secure design: This travel cup applies screw-on construction, which can click securely into the closed position and prevent your drink from leaking.
3. Keep your furniture safe: The coffee mug has a non-skid rubber pad on the bottom so it is safe for your furniture and would not slip.
4. Swing-up closure design: The swing-up closure help you easy to open and close with one hand when driving or busying.
5. Silicone cup cover: Also uses matte finished surface and adds silicone cover to the body so you can hold it comfortably.
6. Made of 304 stainless steel interior, food-grade silicone and PP exterior, no odor peculiar smell when you drink.
7. Suit for car cup holder: The attractive coated and compact shape fits all standard cup holders, and easy to hold.
8. Easy to clean: the lid can be removable so it is easy to clean your cup with hands.
Note:
1. Please leave room when you fill the beverages so that you can screw in the top well without leakage.
2. Please wash this travel cup by your hands, the dishwasher is not recommended.
[ Coffee Stays Hot and Cold ]: This coffee mug applies high quality double-walled stainless steel construction to keep your drink at its original temperature for up to 6 hours. The stainless steel 304 construct also ensure the long-lasting flavor of your drink with no peculiar smell.
[ Easy to Drink with One Hand ]: Travel coffee mug includes an eco-friendly flap opening that makes drinking one-handed a breeze. And the surface of the lid also has a straw hole design, which allows you to drink straight from the cup or use a straw. Comes with a silicone cover on the body, it can help you hold it comfortably.
[ Reliable Screw-On Leakproof Lid ]: It uses a screw-on lid design, which can click securely into the closed position. If the lid latched, you can turn the travel cup at any angle with confidence and don’t need to worry about it will spill and cause leaks in your travel or office bag. Just bring your beverages to go!
[ Non-slip Rubber Cushion ]: There is a rubber cushion on the bottom of this coffee cup that helps stop it from sliding about and protect furniture from scratches and chips. Also, the flip-top can be fixed to the other side, so you don’t need to worry that it would hit your nose when drinking.
[ Excellent Performance at Many Occasion ]: 380ml/12oz capacity is a portable travel mug when you are on the go. It is still lightweight even it is full of beverages. And the lid of this cup has a protruding part so it is easy to find the hole without looking when driving. A good ideal for indoor and outdoor use, such as home, travel and car.
