Megatek Emergency NOAA Weather AM/FM Radio with 5000mAh Battery USB-C Phone Charger, Hand-Crank/Solar Powered Survival Radio with Flashlight, Reading Light and Headphone Jack
Price: $29.99
(as of Aug 17, 2024 11:00:35 UTC – Details)
Megatek Weather Radio-BrandStoryMegatek Weather Radio-BrandStory
MEGATEKMEGATEK
MEGATEK is a leading developer and manufacturer of advanced weather radios.
Utilizing cutting-edge technology, our radios ensure clear reception and durability, even in the most extreme conditions.
With a focus on innovation, quality, and customer support, we strive to be your first choice for emergency preparedness.
Company missionCompany mission
Our Mission
MEGATEK is committed to empower individuals and families to stay informed, connected, and safe during severe weather events through the development and manufacturing of reliable and innovative emergency weather radios.
RadioRadio
Weather Emergency Companion
Reading LightReading Light
Your Reading Light Companion
FlashlightFlashlight
Illuminate Your Adventures
Portable and DurablePortable and Durable
Stay Connected Anywher
Emergency WeatherEmergency Weather
The Perfect Emergency Pick
Customer supportCustomer support
Always Here to Support You
5000mAh Phone Charger: The built-in next generation 21700 type Li-ion battery with 5000 mAh high capacity and improved performance, provides up to 40 hours radio play or 20 hours of lighting, and bigger power to charge your cell phone during the emergency.
NOAA/AM/FM Radio: Tune to 7 NOAA weather stations to receive information and alerts for various life-threatening weather events such as hurricanes, cyclones, tsunamis, storms, and other weather disasters, and listen to news, music, and sports on AM/FM with improved reception. Connect to the 3.5 mm headphone jack for private listening.
Simple SOS Operation: The separate SOS slider allows you to easily and quickly activate SOS alarm with loud siren sound and the SOS flashlight beacon using the bright CREE LED (130 Lumens) to signal for help.
Multiple Power Sources: The WR-21 emergency radio features 5 power source options to keep it running, including the built-in 5000mAh rechargeable Li-ion battery, hand-crank generator, solar panel, USB-C charge in, and 3 x “AAA” battery backup (not included), making it a very useful emergency preparedness item for both outdoors and indoors.
Flashlight & Reading Light: The integrated 3-mode flashlight and 5-LED reading lights provide handy and bright Illumination during camping, hiking, power outages and emergencies.
Portable and Durable: Measuring just 3.6″ H x 6.2″ W x 2.5″ D and weighing 0.8 lbs., the Megatek portable weather radios is designed small and light to perfectly fit in your pocket, backpack, or suitcase, for hiking, trekking, or other outdoor uses. Its build of superior material and rugged housing makes it reliable and durable.
What You Get: Megatek WR-21 weather radio, USB-C charging cable, lanyard, user’s manual, 12-month-replacement warranty, and friendly lifetime customer service.
