Master Tailgaters Replacement for Hyundai Tucson w/Navigation System (2010-2013) Backup Camera OE Part # 95790-2S000, 95790-2S010
Price: $129.99
(as of Sep 25, 2024 08:15:21 UTC – Details)
master tailgaters dash cams backup cameras accessories based in america usa los angelesmaster tailgaters dash cams backup cameras accessories based in america usa los angeles
Master Tailgaters Replacement Backup Camera
replacement backup camerareplacement backup camera
Replaces Model Number: 95790-2S000 (957902S000), 95790-2S010 (957902S010)
For use with:
Hyundai Tuscon (2010-2011) w/ Navigation SystemHyundai Tuscon (2012-2013) w/ Navigation System
We’re proud to mention that our backup camera features sensors from On-Semi, a leading American sensor manufacturer, and lenses from Nidec, a renowned Japanese brand. These high-quality components work together seamlessly to provide you with a backup camera that delivers exceptional performance and reliability.
call parts department find part numbercall parts department find part number
check part numbercheck part number
buy after confirming part numberbuy after confirming part number
Before placing an order for this item, we highly recommend reaching out to your local dealer’s Parts Department.
By doing so, you can determine the exact Part Number that you need to ensure a perfect match for your vehicle.
Don’t take any chances – prioritize finding the correct part before making a purchase.
It’s essential to double-check your Part Number against ours to confirm that you’re ordering the correct item.
A common error is to solely rely on the car’s model and year when purchasing car parts, which can result in acquiring an incorrect item. To prevent this, compare your Part Number to ours and ensure they are identical.
After completing the first two steps and confirming a match between your Part Number and ours, you can purchase this camera with complete confidence.
Knowing that you have the correct item for your vehicle, you can be confident that it will work seamlessly after installation.
specs specificationsspecs specifications
instal installationinstal installation
contact help questionscontact help questions
Sensor: ¼” On-Semi (USA) CMOS Active Pixel Array, Lens: Nidec (Japan) (Glass + Plastic)Minimum Illumination : .1 Lux light sensitivityEffective Pixel : 728 x 582Electronic Shutter : 1/50 to 1/100,000 secondsAngle : 170 DegreesPower : DC 6V-12V
Plugs into Existing OEM Video HarnessResolution : 600 TV linesWaterproof Rate : IP68Video Cables: 17 inchesReplaces Part Number: # 95790-2S000 (957902S000), 95790-2S010 (957902S010)To avoid ordering the wrong item, please double-check your Part Number by referring to your parts catalog or consulting with your local dealership.
Please note that this backup camera is an aftermarket product and not an OEM replacement. It is designed to plug into your existing wire harness, but it will not function if your vehicle does NOT have a backup camera system.Before placing an order, we strongly advise double-checking your part number to ensure compatibility.
america american us usa company master tailgaters small businessamerica american us usa company master tailgaters small business
Why Master Tailgaters?
Master Tailgaters is a US-based company that designs and tests all products in the USA to ensure their quality. We carefully inspect every item and offer in-house support for prompt assistance. Choose Master Tailgaters for high-quality products and top-notch support from an American company.
**ATTENTION: Before purchasing, make sure to call your local dealer to verify that your part number is an EXACT MATCH to this part number*
[Replaces]: OE Part # 95790-2S000 (957902S000), 95790-2S010 (957902S010)
[Fits]: Hyundai Tucson (2010 2011 2012 2013) w/ Navigation System
[Resolution]: 600 TV Lines
[Plug and Play]: Plugs into Existing OEM Video Harness
