Price: $109.99 - $76.49
(as of Aug 27, 2024 23:00:32 UTC – Details)
MULTIFUNCTION
MULTI OUTPUTS FOR DIFFERENT CIRCUMSTANCES
PRODUCT SPECIFICATIONS
Built-In Battery 150Wh/13.5Ah, 11.1V (equivalent to 40,540mAh, 3.7V) Full Charge Time with Adapter Approx. 7hrs Adapter Input DC 15V⎓2A Solar Panel Input 13V-22V⎓2A Max 4*DC Output 9-12V⎓10A, 15A Max 1*USB A QC3.0 Output 4V-9V⎓2.1A Max (QC3.0) 3*USB A Output 5V⎓2.1A Max 2*AC Output 110V/60Hz, 2 prongs&3 prongs outlets AC Continuous Output Power 100W(Peak 150W) Bulb Type 2*1W Ultra Bright LED Flashlight Working Temperature 14℉-104℉(-10℃-40℃) Storage Temperature 14℉-113℉(-10℃-45℃) Product Size(L*W*H) 7.26 x 4.66 x 4.31 inches Product Weight 2.9 lbs Model MARBERO M270
CPAP APPLICABLE
Emergency uses when in the blackout or the hurricanes. The CPAP is always the most important needs for some people, it will run the CPAP for 3.5hrs in fully recharged. It will be your great partner in the emergency situations.
EASY TO STORE AND CARRY
It weighs only 2.9lbs and measures 7.2*4.6*4.3, which is convenient to carry with the handle. It is ideal for using in car, camping, travel and outdoor photography thanks to its super light weight and portable size.
MODEL COMPARISON
4.2 out of 5 stars
789
4.2 out of 5 stars
789
4.2 out of 5 stars
5,294
$76.49$76.49
$169.99$169.99
$99.21$99.21
BATTERY CAPACITY
150Wh/40,540mAh
222Wh/60,000mAh
167Wh/45,000mAh
88.8Wh/24,000mAh
88.8Wh/24,000mAh
AC OUTPUT POWER
100W(Peak 150W)
200W(Peak 300W)
100W(Peak 200W)
80W(Peak 120W)
80W(Peak 120W)
AC OUTLET
2*AC(2 prongs & 3 prongs)
USB A OUTPUT PORT
1*QC 3.0/3*Normal 2.0
1*QC 3.0/2*Normal 2.0
2*QC 3.0/2*Normal 2.0
USB C OUTPUT PORT
1*PD 18W
1*PD 18W
1*PD 18W
1*PD 18W
DC OUTPUT PORT
4*DC 5.5mm
5*DC 5.5mm
2*DC 5.5mm
1*DC 5.5mm
1*DC 5.5mm
PRODUCT SIZE(L*W*H)
7.2*4.6*4.3 inches
9.2*5.9*5.4 inches
8.2*3.5*7.4 inches
3.8*4.7*5.3 inches
6.5*3.1*4.6 inches
PRODUCT WEIGHT
2.9lbs
5.4lbs
4.8lbs
2.4lbs
2.3lbs
SUFFICIENT CAPACITY: The power station has a power capacity of 150Wh/40,540mAh 3.7V which the camping power supply can power most electronic devices efficiently. It can fully charge the mobile phone 24 times, the laptop 3 times, the CPAP machine 3 to 3.5 hours, the led light 24 hours and the mini refrigerator 3 hours. Applicable for emergency situations such as hurricanes, earthquakes, off-grid camping, short blackouts, etc.
MULTI-OUTPUTS: The portable power station is equipped with 3*USB port(5V/2.1A Max),1*QC3.0 USB port(4V-9V/2.1A Max), 4*DC 55*21 port(5-12V/10A with 15A MAX) and 1*AC output socket(100W with 150W peak) which can simultaneously charge your smart phone, iPad, tablets, camera, radio, night light, mini fan and camping essentials under 100W which is perfect for meeting, camping and emergency.
PRO FLASHLIGHT: There are 2*LED flashlights built-in on the side of the power station with 2 lighting modes(steady light and flashing SOS light). Press the LED flashlight switch to change the 2 modes. When you go out camping or experience power outages, this function may help you out.
3 RECHAGRGING WAYS: There are three methods to charge this portable power station. The package includes two adapters, you can charge it by wall outlet or by car adapter(12V). Or it can be also recharged under the sun with a solar panel(15V-24V/1.2A)(not included).
SECURED & ASSURED: With the technology of Battery Management System (BMS), it enables the voltage control, temperature control and more advanced safety controls. Designed with the cooling vents on its back to help this portable power supply stay in a constant temperature range by avoiding internal electrical elements to be damaged. When it comes to short circuit or overpowered, it will automatically and immediately shut off the power to protect itself and the powered devices.
PACKAGE INCLUDES: 1*MARBERO Portable Power Station 150Wh M270, 1*power adapter DC 19V⎓2A , 1*car cigarette lighter,1*12V car charger output cable, 1*user manual. 12 months warranty, 7*24 hours prompt and friendly customer service. Any questions, please contact us, our customer service team will help you.
