Mammoth Cruiser Cooler, Insulated Hard Ice Chest, Tan with 2nd Amendment & US Flag Decal Wrap, Great for Lunchbox, Golf Cart
Price: $189.99
(as of Aug 26, 2024 19:00:20 UTC – Details)
Great for small quantity and short-term cooling needs. Often used as a lunchbox for those hot summer days. Feel safe leaving your Mammoth lunchbox in the truck knowing that your meal is not spoiled by the intense heat in the closed-up cab. For after work, it also perfectly holds a 12 pack of cans so you can easily take iced down cold ones with you. Ideal for: lunchbox, work truck, golf cart, medications, in the dugout. Specifications – Capacity: 12 quart – 12 cans. Measurements: 15.9″ length x 10.5″ width x 11.6″ deep.
MAMMOTH CRUISER 20 COOLER: Insulated medium-sized ice chest created to keep 12 qts chilled. Cooler’s compact design makes it ideal as a lunchbox for your work truck, golf cart, or in the dugout. Great for small quantity and short-term cooling
DURABLE CONSTRUCTION: The double-walled rotomolded construction, freezer grade lid gasket, and built-in stainless steel hinge system of this hard cooler keeps your cans chilled and your lunch from spoiling in the intense heat of a closed-up cab
PORTABLE: Featuring a sturdy metal handle and lightweight size, the ice chest can function as a cooler lunch box. Cooler also has and thick rubber non-skid feet, which prevent unwanted sliding or shifting in the back of a moving truck or rocking boat
SPECS: Outside Measurements – 15.9″ x 10.5″ x 11.6″ , Inside Measurements 12″ x 7″ x 7.2″ , Empty Weight – 8 lbs., Capacity – 12 Quarts, can fit 12 cans, with 2 or more days of ice retention, in Tan with 2nd Amendment & US Flag Decal Wrap
MAMMOTH COOLERS: The coolest thing since the Ice Age. Molded coolers, soft cooler bags, and tumblers built for the field, the water, the tailgate party, the backyard and more. All backed by a Lifetime Warranty
