Price: $99.99
(as of Sep 23, 2024 21:45:28 UTC – Details)
Wireless Backup Reversing Camera with Monitor
As a professional company in car camera field, we are always taking customer’s demand into consideration, striving to reduce your concerns during using rear view Camera.
4.3″ color LCD monitor of the rear view camera kit has detail, contrast, and color accuracy to distinguish objects.
12 automatic Infra-red night vision lights of the onboard camera provide good night vision even on the dark night.
The wireless range (70ft) is wide enough to make it work with a range of universal vehicles.
The rear camera is waterproof to IP68. Sunny or rainy, hot or cold, day or night, the camera always works well.
The diagonal viewing angle of 140 ° works great with the blind spot, you know that you are driving backwards safely.
The reversing camera can be adjusted forward and backward to 150 degrees so that you can adjust it to a suitable angle.
Easy Installation:
Place camera above hitch ball and push the power button for 2 seconds on camera until you see a steady blue light. ( This backup camera has a powerful magnetic base which can be directly attached to the back of your vehicle with no other accessories. No drills needed.)
Monitor equipped with suction cup base, 360 degree rotatable, can be installed on dash or windshield as you like.
Put the plug into cigarette lighter port in the vehicle. To power on/off the monitor hold the power button down to 3 seconds
Follow the instructions on the manual to pair and connect.
Package Includes
1 x Wireless reversing camera(Battery included)
1 x Receiving monitor with a gooseneck hitch
1 x User manual
【 Super Stable Wireless Signal Transmission】 With digital wireless transmission, reversing camera kit delivers a stable image, which restores what you see behind your car directly. So you can view your rear blind spot without interference delay and flicker. The wireless range (35ft) is wide enough to make it work with a range of universal vehicles.
【Magnetic bracket, easy installation】 The Rear View Camera for cars can be instantly attached to any metal surface using an extra strong magnetic base without hardware. There is no cable from the reversing monitor to the reversing camera, eliminating the tedious installation process. Since the transmitter is cleverly constructed in the camera, it does not have to be installed separately. Complete kits and easy installation save time.You can easily install and remove at any time
【4.3 inch LCD monitor and IR night view】 The adjustable gooseneck mount of the Backup Camera Kit with monitor has two ways to Install can be adjusted to a comfortable viewing angle. The images on the car mirror monitor screen are clear and legible. The diagonal viewing angle of 120 ° works great with the blind spot, you know that you are driving backwards safely. 12 automatic infrared night vision lights ensure night vision even in the dark night.
【High quality parking camera system】 This dash camera kit is made of high quality ABS material. Precision and durable. The rear camera is waterproof to IP68. Sunny or rainy, hot or cold, day or night, the camera always works well.
【Customer service】 – Parking assistance system with magnetic camera offers free return and exchange service for 3 months. With 24 hour customer service, please feel free to contact us if you encounter any problems.
