Magnetic Wireless Backup Camera with 7-inch Monitor HD1080P Wireless RV/Truck Camera System IP68 Waterproof IR Night Vision for RVs/Trucks/Trailer/Bus/tractor..
Price: $337.75
(as of Aug 17, 2024 07:45:26 UTC – Details)
Magnetic Wireless Backup Camera with 7-inch IPS Monitor for RV Trailer Truck L-SR3-1L-SR3-1
L-S3-2L-S3-2
No Wires, Just power the monitor via the car cigarette lighter’s 12V power supply, it will auto connect after the first time to turn on the backup camera, no need for pairing. What’s more, there is no need to manually turn on the camera every time, it auto sync to turn on or off.
L-S3-3 L-S3-4 L-S3-5 L-S3-6 L-S3-7
L-S3-12 L-S3-9 L-S3-10 A6-A8 L-S3-09
Is this wireless backup camera system easy to install?
Yes, the camera has strong magnetic base, for iron body just need to choose the right position to attach. Don’t worry about non-iron bodies, the kit includes iron fittings, just attach it to the body to hold the camera securely via the magnetic base.
What kind of vehicles can this wireless back up camera be used on? RVs, trucks, trailers, snowplows, tractors, etc.?
Just the right 7 inch IPS monitor with 1080P resolution magnetic rearview camera, no wiring, no drilling, easy to disassemble. As a backup camera for RV or truck, etc. can be perfectly suitable.
Does this back up camera need to be turned on and off manually every time? What is the battery life?
Not at all, the wireless back up camera follows the monitor on/off switch automatically, no need to do it manually every time. The camera can last up to 9 hours of battery life, and it takes about 8 hours to fully charge.
As a wireless backup camera system for trucks RVs.., is the wireless signal stable and can it be synchronized?
The communication ability of dual antennas brings very stable signal transmission, and the images of the camera and the monitor are transmitted in real time without any delay. The best transmission distance is within 50ft.
Does the backup camera system support recording and playback? What memory card storage capacity is supported?
Yes, the backup camera system supports real-time recording and playback function, which can capture the beauty of your journey or save the evidence in case of emergency, and supports memory cards up to 128GB.
RV Backup Camera Wireless with Monitor
【Best Signal with Dual Antennas】Wireless RV backup camera and monitor system features industry-leading dual antennas, delivering a stable and dependable wireless connection. Enjoy uninterrupted video transmission without any interference.
