Magnetic Wireless Backup Camera – LASTBUS Rechargeable Magnetic 2.4Ghz WiFi Backup Camera for Easy Hitching Gooseneck Horse Boat Travel Trailer Fifth Wheels RV Camper, Only for iPhone iPad
Price: $79.99
(as of Sep 21, 2024 23:45:10 UTC – Details)
LOGOLOGO
Rechargeable Wireless Backup Camera Powered by Built-in Battery for iPhone & iPad
wireless backup camerawireless backup camera
With a 9600mAh built-in rechargeable lithium ion battery and magnetic base, you don’t need to do extra power connection for easy installation and use.
Magnetic Wireless Backup Camera & Easy to Install
magnetic wireless backup cameramagnetic wireless backup camera
With the built-in strong magnetic base, this backup camera can be installed easily where you want. Attach this magnetic backup camera on vehicle, no need to pay to hire a mechanic to install.
wifi backup camerawifi backup camera
night vision backup cameranight vision backup camera
ip69 waterproof backup cameraip69 waterproof backup camera
Wi-Fi Backup Camera
► After being turned on, LASTBUS WiFi backup camera will generate its own unique “Car Camera-xxxx” WiFi signal, connect your iPhone or iPad with this “Car Camera-xxxx” WiFi signal, you can get real-time view from the camera through the “Car Camera-xxxx” WiFi signal.
Night Vision Backup Camera
► With the latest infrared led lights, this night vision backup camera can provide you with clean night vision view at night to make driving/backing up/reversing safer.
IP69 Waterproof Backup Camera
► Using full-glue tech, the waterproof backup camera can work well in rainy and other bad weather.
wide view backup camerawide view backup camera
flipflip
lineline
Wide View Angle Backup Camera
► With the latest lens, this wireless rear view camera can provide you with wide view angle & clean pictures.
Image Mirror Flip
► Use the App on your iPhone or iPad to get view from the camera and you can mirror flip the view at your needs to use it as a front view camera or side view camera or rear view camera.
On/Off Parking Assisting Line
► You can choose to show/hide the parking assisting grid line according to your actual needs. Assisting line makes parking safer.
wireless wifi backup camerawireless wifi backup camera
What are in package? Backup Camera x 1 Antenna x 1 Charge Cord x 1 Manual Book x 1
LASTBUS Rechargeable Magnetic WiFi Backup Camera Use the rechargeable magnetic wireless backup camera in just 4 steps:
1. Turn on the camera;2. Attach it where you want (built-in magnetic base for easy installation);3. Use your iPhone/iPad to connect with the camera through the “Car Camera-xxxx” WiFi signal created by this camera;4. Open the App to get real-time view from the camera. Notice:
1. The LASTBUS Wi-Fi backup camera only support iPhone and iPad.
3.7 out of 5 stars
970
4.0 out of 5 stars
380
Magnetic Base
Rechargeable Built-in Battery
9600mAh
Waterproof
IP69+ IP69
Assit Line On/Off
Images Flip
Night Vision
Screen
Use Phone/Tablet/Pad As Monitor Use iPhone/iPad As Monitor
WIRELESS WIFI BACKUP CAMERA FOR iPhone iPad: 【THE CURRENT VERSION ONLY SUPPORT iPhone and iPad】After being turned on, the Wi-Fi backup camera will generate its own unique Wi-Fi signal (No Internet Supported). Use your iPhone/iPad to connect the Wi-Fi and you can get view from the camera on the App. No monitor needed nor supported.
BUILT-IN BATTERY & MAGNETIC BASE: With a 9600mAhh built-in rechargeable lithium ion battery and a magnetic base, you don’t need to do extra power connection. Attach the camera on your vehicle, turn it on and use it. Save 200 dollars of hiring a mechanic to install.
WIDER SIGNAL RANGE: Adopting external antenna interface and including antenna extensio cable in package, the Wi-Fi backup camera can have greater signal transmission. Strong & stable signal from the rear of your truck trailer pickup.
IP69 WATERPROOF & NIGHT VISION CAMERA: Using full-glue tech, this backup camera can work well in rainy and other bad weather. The latest infrared LED lights can also provide you with a clear and long-distance night view.
