LUCKYERMORE 50 QT Cooler with Rotomolded Insulated Container, 330ml Capacity, 2 Built-in Lock Plate Bottle Openers, 2 Cup Holders, 45cm/18in Ruler, Non-slip Feet
Price: $124.99
(as of Sep 07, 2024 13:30:12 UTC – Details)
🧊 High Performance Cooler- Keep cold up to 5 days with full ice. Recommend 1:1 (ice : contents) for 3 days retention. Ask for longer, you can pre-cool the contents and our cooler if possible. Avoid too close to any heat source or direct sun if possible. And only open the cooler when needed.
💪Rotomolded Insulated Cooler- Constructed with LLDPE plastic and Insulated with polyurethane foam for superior insulation and strength. Also equipped with heavy duty silica gel lid T-latches for secure lid closure, thick insert thermal gasket for maximum chill and wide reinforced hinges to ensure higher performance.
🥂 Convenient Features- 2 Built-in lock plate bottle opener, 2 cup holders for outdoor gathering; 45cm/18in ruler on top for fishing; Non-slip feet to keep still when vehicle in motion; Leak-proof drain plug to release both water and pressure for easy cleaning and opening.
👍 Cooler Capacity- 50 QT cooler could put 80 cans(330ml) inside without ice. Inner dimension: 26.3”x16”x16.7”. Removable handle with Ergonomic Grip for comfortably lift and carry.
🏕️ Have a Cool Life- Perfect companion for outdoor activities, hunting, picnics, barbecues, camping, boating excursions , road trips, home events, or tailgating at your favorite game.
