LIPOWER G1600 Portable Power Station LiFePO4 2000W Solar Powered Generator, 1460Wh With AC Outlets Battery Backup Power Supply For RV, Outdoor Camping, Power Outage (Yellow)
Price: $499.00 - $1,499.00
(as of Aug 15, 2024 23:00:27 UTC – Details)
PORTABLE POWER STATIONPORTABLE POWER STATION
LIPOWER MARS Series
Solar Panel & Accessories
LIPOWER 300W Series
LIPOWER 300W Series
LIPOWER 1000W Series
33
About us
LIPOWER, founded in 2012, is an enterprise promoted by engineering technical team, having a vision to be Leading Outdoors Power Station Energy solutions provider globally.
We provide high performance, safe, convenient and renewable power for life, no matter for adventures, household backup power, camping outdoors and RV.
BETTER GENERATORBETTER GENERATOR
POWER ANYTHING, ANYWHERE, ANYTIMEPOWER ANYTHING, ANYWHERE, ANYTIME
solar generator 2000wsolar generator 2000w
POWER FOR YOUR OUTDOORS LIFEPOWER FOR YOUR OUTDOORS LIFE
solar generatorsolar generator
Product Dimensions ‏ : ‎ 12 x 9 x 13 inches; 43.75 Pounds
Item model number ‏ : ‎ MARS-2000
Batteries ‏ : ‎ 1 Lithium Ion batteries required.
Date First Available ‏ : ‎ August 8, 2022
Manufacturer ‏ : ‎ LIPOWER
ASIN ‏ : ‎ B0B8N61197
ENHANCED EV-GRADE LiFePO4 BATTERY: The LIPOWER G1600L features an EV-grade LiFePO4 battery cell for long-term durability and an assured 3,500+ charging cycles to 80% of its original capacity. The LiFePO4 battery type can charge faster, last longer, and offer optimal safety compared to the lithium-ion battery used by most power stations today.
SIMPLEST SOLUTION OFF GRID: The G1600L portable generator can accommodate almost all appliances for home and outdoor camping, emergency, and other scenarios as a power backup supply. Whether powering your refrigerator, coffee machine, microwave, electric kettle, tailgate, TV, lights, fans, heaters, or other drilling tools, with this unit, you will get it done quickly, efficiently, and with optimal convenience.
RUNS YOUR APPLIANCES LONGER: With a capacity of 1460Wh, this portable battery pack is able to run for a long time when you are enjoying a camping trip or suffering from a power outage. The G1600L can run as a battery generator backup a 25 cu. ft. fridge for 8–24H or a 500W space heater for 2.5H.
ALL THE PORTS IN ONE: Charge up to 10 devices at once! The G1600L power station has 3 AC outlets that can put out 2000W, as well as 2 regular USB-A ports, 1 QC 3.0 fast charge, and 1 60W USB-C port, which allows tablets to charge at full speed. It also has 2 DC ports and 1 car port for CPAP, mini fridge, etc.
CLEAN AND FLEXIBLE RECHARGE: The G1600L solar-powered generator will charge from 0–80% in 4.5H when dual charging through the DC input and Type-C ports, whereas combining the G1600L with 2 APOLLE 100 solar panels will take 9H to be fully charged, making it a simple power solution for camping, overlanding, fishing, and road trips.
SECURE OPERATION: Security is the priority, from hardware selection to software design. G1600L has a lower noise level than other power sources, thanks to its intelligent cooling system; the quick heat dissipation creates a cooler and safer environment for the battery and a more stable power supply performance for your appliances, thus extending battery service life up to a decade.
WHAT YOU GET: The G1600L portable power station, AC adapter, Car charger cable, Accessories storage bag, MC4 to DC solar power extension cable, Detailed user manual, Worry-free 24-month warranty and reliable customer service.
