Large Ice Packs For Coolers and Ice Chest by Portion/Perfect – 20 Minute Quick Freeze Long Lasting Freezer Packs – Slim, Sealed and Reusable Ice Substitute 13 x 10 inch – Set of 2
Price: $29.95 - $24.95
(as of Aug 16, 2024 11:30:11 UTC – Details)
Does this sound familiar?
You used ice packs that have not delivered when you needed them the most leaving your food and beverages warm and soggy?
Then our long-lasting ice packs are for you
We know you want and deserve the best and we got you covered
Stop wasting time loading coolers with pounds of ice with this 17-ounce Portable Ice Freezer Pack featuring a slim, durable plastic design that makes storing and transporting foods and beverages a breeze! It’s perfect for packing for events, outdoor parties, picnics, tailgating and more. Ice pack works perfectly with any soft-sided, foam or plastic insulated cooler
100% Money back guarantee! Our freezer packs for coolers come with a 7-year money back guarantee from the manufacturer
Features / Benefits:
Colder than Ice ❄️
Freeze time under 25 minutes
Cooling time up to 24 hours depending on use
Non-Toxic BPA Free Plastic case
Weight 2 lbs
Dimensions 13 in x 10 in x .5 in
Click Add To Cart Now and start saving money
THE ONLY LARGE 13 X 10 in READY TO GO COOLER ICE PACKS If you are having a outdoor party, picnic or are camping, tailgating you would want these in your cooler, lunch box or lunch bag; No need to fill with water or iron seal shut; Just freeze and go
SUPER FAST FREEZE TIME in less than 25 minutes; Filled with non toxic refrigerant liquid which due to the high latent heat of fusion of water absorbs large amount of heat before warming above 0 degrees resulting in faster and longer cooling time
DESIGN WITH YOU IN MIND We specifically designed these to accomplish best possible cooling effect without taking up your entire cooler space; Only half inch thick, these ice packs have a large frozen surface area which keeps beverages super cold
REUSABLE AND REFREEZABLE Made from hard BPA free PP plastic shell and typically last for over 5000 uses; Keep your food and beverages super cold without messy cleanup of heavy melted ice water; Can be used for shipping or keeping fishing bait cool
